Ok guys! I'm still hearing banging, clicking evertime I hit the gas pedal hard...
Old Oct 5, 2003 | 04:39 PM
KDLMax
I have a Cattman Y-Pipe and Racing pipe. I have looked underneath the car and found nothing. I took off the cross member bar and that didn't end the noise. I've had this banging or grinding noise ever since the Y- pipe was installed 5 months ago. What the heck could this be?
Old Oct 6, 2003 | 08:18 AM
Phatmax98's Avatar
Don't know for sure man, I hear something similar everytime i get on my gas, and it happened after I had my stillen y-pipe installed. I had it checked out and it turned out to be loose parts in my suspension due to constant "getting on the gas." They tightened them up and it seemed to be good for a while. Then I guess they came loose again or I need new bushings.
Old Oct 6, 2003 | 11:18 AM
kratz74's Avatar
Did you just look under the car or did you get under there , grab different parts of the exhaust and shake it. If you didn;t shake it-try it. Chances are when you hit the gas it causes a lurch which in trun caused your exhasut to sawy a bit. You can adjust your hangers on your muffler (the rubber bands) or bend the supports around your cat. Its probaly your exhaust banging.
kjlouis
Nov 24, 2018 06:09 AM
maxipower
Aug 21, 2015 11:10 AM
Gsantos79
Aug 8, 2015 07:41 AM
00 Max
Aug 4, 2015 07:09 PM
Jcof88
Aug 3, 2015 10:43 PM
