e-brake disassembly?
Old Oct 5, 2003 | 06:39 PM
J_Spec's Avatar
just wondering if i had to remove the whole center console to be able to replace the hand brake components (shift boot, handle). and if so how.
Old Oct 5, 2003 | 07:00 PM
greg82's Avatar
Just remove the trim around the shifter, if you lose any clips, find them. Where the back of the piece snaps into the console there are two slots on each side, the wire frame of the e-brake boot clips in underneath the one on the left.
greg
Old Oct 5, 2003 | 07:06 PM
twiggy144's Avatar
the center console is easily removed. Held in place by 4 screws only. 2 of them are by the rear endon each side of the console. They are visible and very easily found. The other two are behind the plate cover surrounding the stick shift gear indicator (auto tranny) . Pry out this plate, and you will see the 2 screws at the very front of the console.
KabirUTA13
19
Oct 17, 2015 02:15 AM
Lowered_a33
Aug 24, 2015 04:35 AM
Y2KevSE
72
Aug 4, 2008 08:21 PM
buckwilly4
Sep 20, 2001 02:37 PM
Max2000
Nov 24, 2000 05:56 AM
