cleaned my throttle body, now car is much slower
Old Oct 7, 2003 | 06:02 PM
raynist's Avatar
I have a 2000, but the engines are basically the same.
I cleaned my TB the other day and now my car is running like crap. I first sprayed into the TB with the car off, then turned it on and sprayed while it was running. I took off my Frankencar intake and sprayed directly into the TB. I had a SES light when I got back in the car. I disconnected the battery for an hour and the light went away. The car has much LESS power now. It will not rev as freely as before. If I accelerate about 1/3 throttle in first gear, you can feel it fall flat at 4300 rpms which I suspect is the point it switches over to the shorter intake runners. Could I have clogged or jammed the assembly that switches the intake runners over to the shorter ones? Did I not reset my ECU for long enough? In resetting my ECU, will I need to drive for some time before it performs well again? I drove about 35 miles today and it is still much less powerfull. The car runs and idles smoothly, but really lacks power in the upper rpms.
--Ray
Old Oct 7, 2003 | 06:16 PM
Maxtank's Avatar
1. Check that your MAF is connected
2. Did you spray into the MAF? sounds like some may have got on there.
Old Oct 7, 2003 | 07:39 PM
ch13f's Avatar
3. Don't post in multiple places....
Old Oct 7, 2003 | 07:43 PM
davey6693's Avatar
The same happened to me when I forgot to plug the MAF back in. You should always be running better after a successful TB clean.
Old Oct 7, 2003 | 07:44 PM
raynist's Avatar
Why not?!?!?!?!
Why only post on the 5th gen forum and possibly miss getting the answer to my question? I am sure many of the 4th gen people do not read the 5th gen posts.
--Ray
Old Oct 7, 2003 | 07:53 PM
Jatan's Avatar
Originally Posted by raynist
Why not?!?!?!?!
--Ray
That's why they have a General forum...
Since you unplugged the battery, your ECU might be relearning or something Give it a few days to adjust. Make sure you plugged everything back in tight so you don't have an air leak.
Old Oct 7, 2003 | 08:00 PM
SXN's Avatar
SXN
there is a general forum, and if its a 5th gen, it goes in the 5th gen forum...
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
Samedi
Aug 13, 2015 04:05 PM
Balkins
Aug 12, 2015 06:39 AM
