Disconnecting headlight from factory alarm?
Old Oct 10, 2003 | 11:30 AM
optimus310's Avatar
Is there a way to disconnect my headlight from the factory Alarm and have the Blinkers turn on instead when the alarm goes off?
My Headlights need to warm up and flashing them will kill the life of my bulbs, so I don't want them to turn on.
Old Oct 10, 2003 | 11:35 AM
MaxedOutOfCash's Avatar
Pizda Boy
never heard of the headlights blinking when engaging/disengaging the alarm. . .
i'm pretty sure everybody's blinkers just turn on.
mine do.
Old Oct 10, 2003 | 12:05 PM
Chunger's Avatar
My other car is a Hybrid
I think he means when the factory alarm is SET OFF...
I need to figure this out as well as HID capsules need the warm up time.
There may be an extra wire at the relay box... I haven't had time to check... Please let us know what you find... If the wire is found, it would be a simple matter to redirect it to the hazard lights.
Old Oct 10, 2003 | 12:09 PM
Pizda Boy
doesn't the alarm use the high beams???
Old Oct 10, 2003 | 12:14 PM
optimus310's Avatar
I don't think they do but if thats the case diconnecting my highbeam wire will fix this problem. Will need to try that.
Old Oct 10, 2003 | 12:31 PM
1MAX2NV's Avatar
Cut the wire from the body control module?? I'm guessing.
Old Oct 10, 2003 | 12:32 PM
Pizda Boy
i'm positive they use high beams, because i do not high beams since i have hid's and nothing blinks when alarm is on.
Old Oct 10, 2003 | 12:37 PM
optimus310's Avatar
Thanks for the Tip man. Now I just have to find a way to make my parking lights turn on instead.
I still have to try disconnecting the wire.
Old Oct 10, 2003 | 04:11 PM
csnow's Avatar
I'll kill you. I mean it
I have a KARR alarm and Osram 9004 HID conversion kit on my 97' max. When the alarm is set off the headlights do flash. If you guys ever figure out how to stop them from flashing your advice is much appreciated.
doctorpullit
Oct 28, 2019 10:58 PM
maxima297
Sep 30, 2015 03:32 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
Noela
Sep 26, 2015 08:22 AM
