Car would not start
Car would not start
I have a 1997 Infiniti I30, and had a similar problem as was posted here. The car would not start and left me stranded at the mall last night. A boost did not help, and following the advice from a similar posting, I went back this morning and lightly tapped on the solenoid. The car then started. Back home I took the starter motor off, and everything completely apart. I noticed a lot of black powder in the motor housing and assumed this was from the brushes. I cleaned off all the old grease from the planetary and repacked the gears with a lithium based grease. I also used the same grease in the solenoid portion where a shaft connecting a linkage to the starter pinion, slides within an opening.
Having done all this I am still not sure what was actually wrong, and why the tapping allowed the car to start. Consequently I am not sure my minor rebuild has solved the problem, or whether I should be ordering a new motor and/or solenoid.
Any advice / thoughts would be much appreciated.
Originally Posted by kevlo911
bad starter solenoid
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
