PROBLEMS WITH PR CAI INSTALL...PLEASE HELP
Old Feb 18, 2001 | 12:40 PM
GTRNismo
Alright, i tried to install the PR cai in a friend 1995 max se. We got the first portion in perfect (before tube), and we tested it with just that and cone, and it already made a difference. BUT, heres the problem. He has the APC wiring harness, and with that, the fuse box, and battery, there is definetly NOT enough room for the intake to go in. We tried manuevering it in many way to just get it to meet up with everything, and this is without the whole. But there was defintely NOT enough room for this big pipe to fit in. Is there something that has to be relocated? Anyone else with a 95 se and a PR cAI, please help, thanx.
Old Feb 18, 2001 | 02:24 PM
GTRNismo
TTT, please i need help ASAP with this.
Old Feb 18, 2001 | 03:46 PM
Joe_R's Avatar
Well, I'm not sure how the APC wiring harness plays in but remembering back to when I installed mine, we looked the the fitment for about 20 minutes thinking it would never work. We moved it around every which way. So we drilled using the template and sure enough, it worked. It was tight, very tight, but it was right on. Not sure that helped you.
Old Feb 18, 2001 | 04:10 PM
sx7r's Avatar
you have to take off the fuse box, battery, and battery tray to put the template on. after you drill the hole, and get the pipe in the hole, the fuse box will screw back on but it'll be a little crooked cuz it's such a tight fit.
Old Feb 18, 2001 | 04:39 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
yeah....you have to remove all that stuff...drill the hole...install the piping and then reinstall the rest of the stuff...no need to relocate anything...
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
