Rough Ride In Nyc On Maxspeed's
Old Oct 18, 2003 | 09:12 AM
jetblack5spd's Avatar
i just changed my stock suspension with kyb gr2's and maxspeed springs. the back sags alittle bit and the front still looks like the 4x4 look. when i first got it done by jeff at maxtuning the ride was nice but after about 3 weeks it just got really bouncy. does anyone know of a better set up? im thinking its my springs. also when i go over bumps i could hear a clanging noise of two metal pieces hitting together coming fromm the suspension. please help
Old Oct 18, 2003 | 11:00 AM
driver824's Avatar
upgrade to eibachs. the noise is it coming from the rear. if so then check the rear strut towerr and se if u have the gaskets in. ull be able to see the gasket from the rear. also check the two bolts on the strut tower. if they are the least bit loose ull hear a pop noise every time u hit a bump. good luck
Old Oct 18, 2003 | 11:23 AM
Kevlo911's Avatar
Kevlo for President
http://maxmods.dyndns.org/index.php?MaximaHandling
eibach will ride roguher then maxspeed
Old Oct 18, 2003 | 01:57 PM
Jatan's Avatar
I had the clunking sound from the passenger rear because it wasn't seated properly. After it was seated properly, the noise went away
Old Oct 18, 2003 | 04:07 PM
drewm's Avatar
One (or more) of your shocks might have gone bad. Check for leaks.
Also, everyone has to remember, lowered suspensions will NEVER be as smooth as OEM. It will always be a harsher ride.
litch
123
Jan 4, 2024 07:01 PM
D Mason
Jun 21, 2016 04:43 AM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
