total 60,000 service necessary...
Old Oct 18, 2003 | 08:56 PM
my99maxisnice's Avatar
Is it absolutely necessary to change spark plugs every 60,000 miles (first 60000 coming up soon for me), even if the gas mileage isnt bad, and it drives pretty well? And how much of the 60,000 could I do myself? I am not very mechanically inclined, but I can follow directions. If not, how much does it cost do get a mechanic to do it? Thanks.
Old Oct 18, 2003 | 09:15 PM
outsider's Avatar
you can change the plugs urself, the airfilter, the gas filter is a bit hard to get too, you can basiclly drain the tranny fluid yourself and then refill it.
what else am i missing?
Old Oct 18, 2003 | 09:18 PM
according to the 60000 website for max's:
1) spark plugs
2)oil change
3)fuel filter
4)transmission fluid
5)radiator coolant
6)PCV valve
7)Belt Replacement? It makes it sound like this is only for 95's
8)Tighten Throttle Cable
Old Oct 19, 2003 | 07:32 AM
Jatan's Avatar
How To's: http://forums.maxima.org/showthread.php?t=254238 with links and stuff
Clean the TB and the IACV since you're taking out the intake stuff to change the fuel filter.
Old Oct 19, 2003 | 08:06 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
sparkplugs wearing out is typically a gradual change so its not something you will notice. you might think it is driving well but after they are replaced you should notice a difference. they are very easy to do even if you mechanically inclined. there are plenty of write ups around here that should make it go smoothly.
Old Oct 19, 2003 | 08:22 AM
Maxima99SE's Avatar
will fly for food
my stealership wanted about $430 for the 60K service
Old Oct 19, 2003 | 08:25 AM
Jatan's Avatar
NGK Platinums are expensive so buy the NGK Coppers. Coppers are only like $2 a piece
Old Oct 19, 2003 | 10:01 AM
dtholmanmax's Avatar
Courtesy Service quoted me 525 for the service
Old Oct 19, 2003 | 11:09 AM
Thanks for your help, I don't plan on dishing out all that money...I'll take a look at it all, I plan on changing oil, and taking a look at the spark plugs since it should be easy. Are the Spark Plugs installation what costs all the money?
Old Oct 19, 2003 | 01:39 PM
Jatan's Avatar
You can do it yourself:
Spark plugs http://www.vqpower.com/v2/modules.ph...howpage&pid=33
Oil change http://www.motorvate.ca/mvp.php/511
Fuel filter http://vbxmaxima.8m.com/fuelfilter.html
Clean TB (http://www.motorvate.ca/mvp.php/517) & IACV (http://forums.maxima.org/showthread.php?t=254238) when you do fuel filter
Transmission fluid http://forums.maxima.org/showthread.php?t=149056
Radiator coolant http://www.motorvate.ca/mvp.php/502
PCV valve http://web.archive.org/web/200111091...k_service.html
They charge you a lot at the stealership b/c they can. They have BS prices on parts and people still go there since they think that it's the best place to go to have it done.
Old Oct 19, 2003 | 03:49 PM
Thanks for the great links...I still have a couple thousand to go though...two things
1)on the PCV valve link, I'm guessing this just means replace it, since it gives no intructions?
2)on the Spark Plug it says, "This is optional, the maxima is recommended to run with Platinum Plugs, however copper provides a better spark and the only down side is it will only last for 30k instead of 60k for platinum plugs." Is it true that copper provide better spark? If so, why are Platinum Plugs recommended?
Old Oct 19, 2003 | 07:32 PM
Jatan's Avatar
Just unscrew the clamp and pull off the hose. Take out the PCV valve and put the new one in. Reconnect the hose and put the clamp back on.
Nissan recommends platinums not sure why, but you can use the copper ones. Copper is way cheaper so I used those
my03maxima
Jul 28, 2024 07:40 AM
05RLS2
Nov 7, 2016 05:52 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
RealityCheck
Oct 2, 2015 06:34 PM
Marc2theMax
Sep 28, 2015 08:13 AM
