View Poll Results: What do you have?
ADDCO
26.67%
Progress
40.00%
Stillen
33.33%
Voters: 15. You may not vote on this poll
Which Rear Sway Bar?
Old Oct 21, 2003 | 06:28 AM
O PIPE's Avatar
Which Rear Sway Bar would you go with?
ADDCO
Progress
Stillen
I am in the process of buying a rear sway bar and because I know pretty well nothing about them I was wondering what the experts here would suggest, and WHY?
Let me know
OPIPE
Old Oct 21, 2003 | 08:58 AM
joew's Avatar
progress progress
Old Oct 21, 2003 | 11:27 AM
LastBoyScout's Avatar
Although i have seen progress and stillen in use, i have seen them to be pretty much the same.
For $$$ value vs performance, progress.
That is what i will buy at some point, unless the stillen goes on sale
Old Oct 21, 2003 | 05:33 PM
drewm's Avatar
Keep in mind the stillen is the only adjustable one
More info:
http://maxmods.dyndns.org/?MaximaSwayBars
Old Oct 21, 2003 | 07:49 PM
maximum810's Avatar
Progress.....but be prepared to make a trip to the local home depot.
Old Oct 21, 2003 | 07:51 PM
MaximaEvolution's Avatar
why be prepared to go to El Dumpo?
Old Oct 21, 2003 | 07:53 PM
maximum810's Avatar
My kit came with a few missing bolts, and improperly-sized washers, and the washers and trailer arm brackets had tendencies to bind up.
Old Oct 21, 2003 | 08:19 PM
tlrmax's Avatar
I got the addco and it did nothing for the car! Go with one of the other.
Old Oct 21, 2003 | 09:04 PM
KWheelzSB's Avatar
You have to take it out of the driveway.
j/k
I got the Stillen bar secondhand for like $150. Never looked back. Planted, solid, crisp lane changes and directional changes.
Old Oct 22, 2003 | 07:02 AM
tru....stillen is adjustable........
Old Oct 22, 2003 | 08:23 AM
dmBK's Avatar
How 'bout them cliffs?
everyone with stillen - how often do u adjust it? its not that convenient, and unless you race, i dont really see a point. with addco/progress, just install it, set it how you want it to behave, and thats it.
Old Oct 22, 2003 | 11:21 AM
O PIPE's Avatar
Thanks for the replies everybody. Te last comment said " just set it and away you go"
Is there different setting for the so called "non-adjustable" RSBs
( progress Addco???)
by the way, due to the $$ it looks like I am leaning toward the Progress with ply urethane bushings......
Cheers
OPIPE
Old Oct 22, 2003 | 11:38 AM
dmBK's Avatar
Cheers
OPIPE
what i meant was, you can adjust how your car will handle by where you place the links that connect the sway bar to the "axle". i set mine about 2-3 inches from the bends on yeach side. i believe where you set them will affect your understeer/oversteer. there were many threads on the subject. try SEARCHing for it. btw, with my set up the car is neutral.
Old Oct 22, 2003 | 01:35 PM
O PIPE's Avatar
Thanks for the info, that exactly answered my question
Cheers
OPIPE
Old Oct 22, 2003 | 01:49 PM
Jeff92se's Avatar
I'm needing a caw
How THICK is the progress / addco?? Get the thickest one.
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
bbsitum
Sep 11, 2015 04:55 PM
flu2000
Sep 8, 2015 02:23 PM
