Whats the word on: Cattman Headers & JWT Cams
Old Oct 24, 2003 | 06:31 AM
  #41
kenji's Avatar
Originally Posted by Dave B
There's no need to go above 7200rpms with the stock cams. I don't think anyone has a 7200+ rpm limiter on their NA Maxima.
Dave
He said with cams..
Old Oct 24, 2003 | 08:08 AM
  #42
Ninos_Maxima's Avatar
be the change u want2C
Originally Posted by slammed95
That's how the S2000 makes so much power, the engine breathes well enough at high speeds, that even with a peak torque of only 151lb-ft, it makes 240hp.
Wait, If we unlock our engine like the S2k then @ 205ft/lbs our car should put out like 300-350, The s2k is a v6 right? Whast the stock Exhaust setup?
Old Oct 24, 2003 | 08:31 AM
  #43
kenji's Avatar
woah man, not tryin to flame but try and research or something before you make assumptions. an s2000 is an inline - four cylinder aluminum block 16v DOHC VTEC RWD, which produces 240 HP @ 7800 RPM.
Thinking that you can simply 'unlock' something in an 8 year old motor design, dream on.. I hate to mention that comparing hondas to nissans, let alone a new inline4 to an 8 year old v6, is like comparing 'apples to oranges'.
Old Oct 24, 2003 | 08:36 AM
  #44
NOMAD MAXIMA's Avatar
Originally Posted by ivelweyz
Not much gain over a y-pipe. Also the NOMAD MAXIMA unless you have a current dyno I wouldn't waste maney on doing it after the install, unless you only want to know what your numbers are...
I just called Car Tek tuning and I'm going to make an appoitment for the Dynoing so I can be friend's with everyone, OK! They charge $75.00 for the Dyno and 175.00 an Hour for tunning. That's beter than I expected.
However I'm getting the work done at another
shop(Headers-Catback) then I'll go back and Dyno again. Cool? Also I would like the guy here on the org in Weston to meet me there as a witness.
Old Oct 24, 2003 | 08:37 AM
  #45
nismology's Avatar
Big HP/liter isn't Nissan's philosphy and never will be. Only way you can get an engine to breathe that well at high RPM while maintaining decent drivability is variable valve timing and lift.
Old Oct 25, 2003 | 01:16 AM
  #46
SXN's Avatar
SXN
yes that would be the entire point of the new cams, to slightly bend nissans philosophy. also thats why they made race and mild cams, driveablity on one hand, power on the other. no clear dynos or info yet though?
Old Oct 26, 2003 | 03:58 PM
  #47
amaxeatinvtecs's Avatar
holy crap, is it still too late? i just got back from orlando today(26th) and i dont know whats even going on with my headers im yet to hear from my mechanic, is youres a cali spec or fed? Since i cant reallly afford a dyno i definantly wanna see what numbers u get
Old Oct 26, 2003 | 08:17 PM
  #48
Nealoc187's Avatar
SLOW
$175 an hour to tune is ungodly high. The highest I have ever seen previous to this post was $130 an hour.
Old Oct 26, 2003 | 10:48 PM
  #49
Fed spec. Call Maroone Nissan give them your vin number and they will tell you. Also it's here on the org somewhere.
Old Oct 27, 2003 | 06:31 AM
  #50
MaxSpeedSE's Avatar
Let me get this stright, the 4th gen cams are less agressive then the 5th gen cams?
Old Oct 27, 2003 | 08:12 AM
  #51
nismology's Avatar
I've heard the cam argument go both ways, so I am confused about this as well...
Old Oct 27, 2003 | 08:14 AM
  #52
infinitiblast's Avatar
2k an 2k1 turn out to have a cam profile of .232-.238 which wont be any better than what us 4th gens have..the ony 5th gen model is the 3.5 that has a nice cam profile that would give us a little gain. But getting it to work is going ot be hard.
Old Oct 27, 2003 | 08:51 AM
  #53
MaxSpeedSE's Avatar
95 models have slightly higher lift cams than other 4th gens. The other specs are the same.
How are the 95s alone diffrent then the 96-99 ???
Old Oct 27, 2003 | 09:04 AM
  #54
MaxSpeedSE's Avatar
That dosent make sence but oh well, if they came out with more agressive motors...when they sold them you would figure there hp ratings would be higher...
But i have a question and this goes out to EVERYONE. If the 2000-2001 makes 30 more hp then the 4th gens off intake manifold and exhuast... dosent that seem alot? Everyone with a MEVI says that the ECU is need for the great loss of low end...well since the 2000-2001 has a upgraded manifold how come they dident lose low end? do they come with an advanced timming ECU ?
-Chris
Old Oct 27, 2003 | 09:17 AM
  #55
I30tMikeD's Avatar
-Chris
5th gens have a dual intake runner system which is completely different from a MEVI on a 4th gen. With dual runners there is no loss in power.
Old Oct 27, 2003 | 09:55 AM
  #56
just got the car back today, the headers are on and running like a champ, they sound awesome, and yes it pulls me back to my seat, i feel power through all gears
Old Oct 27, 2003 | 10:56 AM
  #57
Nealoc187's Avatar
SLOW
Curious where you got this info I'd like to check into this.
Old Oct 27, 2003 | 11:02 AM
  #58
Not according to the factory service manual they dont...
Old Oct 27, 2003 | 11:09 AM
  #59
MaxSpeedSE's Avatar
I30tMikeD - thanks...i see now. What stops us from putting that on our cars...besides the issue the hood might not close?
amaxeatinvtecs -
Old Oct 27, 2003 | 11:15 AM
  #60
It will also hit the firewall when the engine moves..not to mention getting it to work with your 4th gen egr setup..etc...sure it can be done..just get ready to fork over some $$
amaxeatinvtecs -
Old Oct 27, 2003 | 11:24 AM
  #61
MaxSpeedSE's Avatar
That sucks cuz the MEVI is pointless with out a ECU, and i cant get that cuz im on a nitrous setup
Old Oct 27, 2003 | 11:25 AM
  #62
I30tMikeD's Avatar
amaxeatinvtecs -
5th gens don't use the same throttle system. And yes, the hood would not close either.
Old Oct 27, 2003 | 11:30 AM
  #63
I30tMikeD's Avatar
For one it's not pointless, especially if your running nitrous because you don't need to worry about a little loss in torque. Also, you could get the ECU upgrade if you wanted. It is expensive but JWT will do a nitrous piggyback system that will let you run their NA program then switch to the nitrous program via toggle switch.
Old Oct 27, 2003 | 01:14 PM
  #64
nismology's Avatar
Yea but isn't that for a fixed shot, 65 I think?? What if you wanted to upgrade?? SOL.
Old Oct 27, 2003 | 02:35 PM
  #65
MaxSpeedSE's Avatar
Yea, arnt thoes ecu's for tuned setups? And ive heard that you cant just switched from a retart to advanced timing just instantly cuz the car needs time to learn the change....so i heard
Old Oct 27, 2003 | 03:27 PM
  #66
I30tMikeD's Avatar
I don't know all of the particulars on JWT's nitrous piggyback system, but the point was that you can have both an N/A and nitrous program and switch back and forth. So your not SOL because you run nitrous, you just have to be willing to spend some money.
Old Oct 27, 2003 | 05:43 PM
  #67
nismology's Avatar
What I meant was the ECU is only tuned for a certain shot. There is a discussion about this in the nitrous forum. You give up upgradability for the ability to switch between maps. Upgrade that shot and the ECU becomes untuned for the application. If it was a wet system it wouldn't matter anyway.
Old Oct 28, 2003 | 10:30 PM
  #68
hey nomad whens the headers gona be ready, wanna check out youre ride man
Old Oct 30, 2003 | 11:28 PM
  #69
Iron Lung's Avatar
The cams came in today, Hopefully I will have time to install them this weekend. The headers are ordered but I have no idea when they will be in. Just gotta wait until I get a new fuel controller and I'll dyno again. Will anyone be installing thier own cams/ headers? If so I'll take time to do a write up w/ pics, since JWT didn't provide any instructions.
Old Oct 30, 2003 | 11:43 PM
  #70
DEVIOUS's Avatar
Did you get the valve springs too?
Old Oct 31, 2003 | 12:07 AM
  #71
Iron Lung's Avatar
I can't change the rev limiter on my 99 so I'm hoping they won't be needed. But if the valves decide to float, I'll order a set.
Old Oct 31, 2003 | 05:07 AM
  #72
I30tMikeD's Avatar
Are you going to be doing before and after dynos on both the cams and headers? Can't wait to see the results
Old Oct 31, 2003 | 05:23 AM
  #73
Prodeje79's Avatar
Please do a write-up with pics, please. :>
how much extra would the valve springs have been?
Old Oct 31, 2003 | 11:10 AM
  #74
Iron Lung's Avatar
320 shipped from SWA.
I probably won't dyno before hand I'll just use my previous dyno as a reference. The only thing that has been added since that dyno was the dynomax muffler as opposed to the stock muffler.
Old Oct 31, 2003 | 11:48 AM
  #75
I30tMikeD's Avatar
That should be good enough, as long as you use the same dyno. Good luck on the install!
Old Oct 31, 2003 | 11:49 AM
  #76
MaxSpeedSE's Avatar
Man i cant wait!
Old Oct 31, 2003 | 09:10 PM
  #77
DEVIOUS's Avatar
Good luck with the install.
Are you going to pull out the motor? if not it's going to be hard to remove the the timing cover not much space. oh be careful when tightening the cam bearings or also know as caps, the cams are know to break. due to it been a hollow shaft. well keep us updated.
Old Nov 1, 2003 | 04:09 PM
  #78
Iron Lung's Avatar
I probably will have to raise the motor a little, but hopefully won't have to pull it out. I'm going to toss all of the power steering and ac components. That should give me a little more room.
The headers came in today! I'm hyped about these. Hopefully I'll be able to install everything this weekend.
http://www.cardomain.com/memberpage/411180/2
Old Nov 2, 2003 | 04:47 PM
  #79
Y2KSESteve's Avatar
Can't wait to help get those in!
Old Nov 2, 2003 | 06:07 PM
  #80
MaxSpeedSE's Avatar
I thought it was supose to happen this weekend?
