E-brake sticking at caliper
Anyone had a sticky caliper, specifially the e-brake control? I tried lubung it all up again but it sticks every time. I'm currently driving without using my ebrake.
I don't wanna replace the calipers if I cn avoid it. Anyone had this problem? Got a good fix?
go underneath the rear tires and knock the lever which the wire is on. Knoch that lever to open up. ur caliper may freeze again though.
a guy a carx showed me mine was locked and took a straight screw driver then hammered the little arm the cable connects to back to the open position. look at the opposite side to see which way it goes. reread this 3 times, it may be hard to understand
I drove around for months with a rear caliper frozen. Not only the cable brake was not working, but the hydraulics were not working either on that wheel. I replace the caliper last weekend. I suggest you read my post:
http://forums.maxima.org/showthread.php?t=257978
04-16-2020 05:15 AM
HerpDerp1919
09-29-2015 02:02 PM
imported_Nismo_max
09-21-2015 07:24 PM
bbsitum
09-11-2015 04:55 PM
