Replace Brake Pads?
Replace Brake Pads?
My brakes have been sqeeking...Im not sure if I need new pads or not. First, what should I try to see what it is, it might be dust or something right? Second, if it is brake pads how hard are they to change myself and what pads should I look for?
take off your wheels and check both inner and outer pads to see if they are thin, if so you need to replace them. as far as how hard is it to change it's really not that hard there's 2 14mm bolts loosen the top one and remove the bottom one. flip the caliper up remove your old pads and install the new ones (just remember how the old ones were on) open your reservoir and use a c clamp to compress the piston back in. flip the caliper back down. tighten both 14mm bolts. put the cap back on the reservior put your wheel back on. go into your car pump the brakes and your done.
oh yeah not sure if you have an oreilly's where you're at but i bought my brake pads from them, the brand is called thermal quiet by wagner. payed bout $30 for them and the work well a little squeak bout the first week, but no more squeaks now.
http://www.motorvate.ca/mvp.php/300 will give you detail instruction about how to disassemble your brake system...
Cant_Get_Ryte
08-28-2015 06:41 AM
RealityCheck
08-05-2015 06:18 AM
