Replaced knock sensor, still throwing code
Hello,
I replaced my knock sensor a little while ago and took a ride around the block, shut my car off and checked for codes and I am still throwing the knock sensor code...
Any ideas?
Thanks,
Mike
Any ideas?
Thanks,
Mike
Originally Posted by SteVTEC
could be a bad sub-harnass.
Did you actually measure the resistance across your old knock sensor? What happens if you plug a 470k resistor across the sub-harnass?
I havent tried this.. How many wires should be coming out of the harness.. There is only one coming out of mine, is this normal?
Thanks for you help.
Mike
Once you clear the error, it will take more then a simple drive around the block to make it come back. Especially codes like the KS, O2's, EGR, EVAP ect. An error must happen twice for the ECU to record it. Total failures of major control devices (MAF, Infectors, Timing & Coils) will turn the CEL on immediately.
knock sensor code
try resetting your ecu...search on the forums for the directions on how to do that....if that doesn't work, I heard disconnecting the battery (for like an hour or so), just resetting the ecu is instant...then go for a drive....
one wire going into the knock sensor harness is correct...
did you reset your ecu?
Originally Posted by MikeD95SE
Thansk for the info guys.. Also is it correct that I only have one wire connecting to the KS.. Looks like a very delicate wire too.
Thanks,
Mike
Thanks,
Mike
resetting the ecu is done by turning the self-diagnostic screw on the ecu itself one direction and then the other direction that repeat the process....instructions for doing this are some where on these boards....
Originally Posted by infinitiman96
yes it will if the battery is disconnected long enough like over night, the ecu can not store codes for more then a couple of hours once the battery is disconnected
I have to check for codes again. Im going to check in a little while.
Thanks everyone.
Mike
Hello,
Any ideas?
Thanks,
Mike
Any ideas?
Thanks,
Mike
have u checked ur oxygen sensors...there are 3 and if one is bad it can trigger the check engine light...i recently had the same problem
maybe your engine is knocking occassionally and throwing 0304. I had that code come back multiple times after ECU clearing and I suspected a bad KS. After TB cleaning, and 1 can of BG44K later I got rid of the code w/o replacing the KS (after ECU clearning it has not come back yet for a little over a month so far). The 44k helps get rid of carbon in your combustion chamber, which can lead to knock. TB cleaner and 44k is good for your engine anyways, even if it's not the source of your 0304.
no it won't, search for it in the 4th gen section. you will see that people who left htere battery dissconnected over night did not clear the code/reset the ecu
i've never tried the disconnecting battery method..just heard it works sometimes...what method i know fer sher works is to reset the ecu by using a set procedure by turning the self diagnostic screw one way for a few seconds and then the other, then repeat the process...can't put the process into words very well, but it works for me when i do it...
I am happy to report that my car is no longer throwing any codes
Well it gave me a 0505 which means that no errors were detected. I guess it took a few days for the ECU to reset. Actually I didnt check it after I reset the ECU last time so maybe that worked. Thanks for your help everyone!
Mike
Well it gave me a 0505 which means that no errors were detected. I guess it took a few days for the ECU to reset. Actually I didnt check it after I reset the ECU last time so maybe that worked. Thanks for your help everyone!Mike
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Aug 20, 2015 02:17 AM
doobadoo
Aug 15, 2015 06:43 PM
