Need help with LED KeyRing Mod
Old Oct 25, 2003 | 07:33 PM
Max96LSU's Avatar
I spent the day changing out some bulbs to LEDs (security, Key ring and gauge cluster, etc.) It looks great..will posts pics soon
Anyway, My key ring will not turn off!!! I soldered a wire to the (-) lead of the LED and grounded it to a bolt behind the fuse box. I soldered the 330 Ohm resistor to the (+) Lead. Did I do something wrong? How did you guys do this mod? Any help would be great!!!!
-Matt
Old Oct 25, 2003 | 08:33 PM
araffio's Avatar
Use a size 74 LED bulb, problem solved...
-Tony
Old Oct 25, 2003 | 08:37 PM
Max96LSU's Avatar
Sweet, thanks again Tony! Do you know where else in the car we can use size 74 bulbs?
Old Oct 25, 2003 | 09:14 PM
araffio's Avatar
That's pretty much it. You might be able to use them behind the gauges, if you spread the leads out a little to fit the socket, but they wont throw enough light so dont bother.
-Tony
Old Oct 26, 2003 | 06:02 AM
97GLES's Avatar
-Tony
is the key-ring & auto shifter a 194 bulb?
Old Oct 26, 2003 | 06:07 AM
Kevlo911's Avatar
Kevlo for President
key-ring is a 74
auto shifter is 194
Old Oct 26, 2003 | 06:42 AM
97GLES's Avatar
Originally Posted by kevlo911
key-ring is a 74
auto shifter is 194
thanks for the info
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
lrb6805
Sep 24, 2015 05:03 PM
