ANYONE tried the PHANTOM LSD?
Old Oct 26, 2003 | 07:35 PM
luckee2bhere's Avatar
curious if anyone has it
http://maxmods.dyndns.org/?MaximaLim...pDifferentials
Old Oct 26, 2003 | 07:53 PM
plurco's Avatar
Originally Posted by luckee2bhere
I saw a post where a guy installed one, but he is also building his engine so I don't think it is running yet.
Old Oct 26, 2003 | 08:03 PM
hmmmmmmmmm i see
Old Oct 26, 2003 | 08:06 PM
ivelweyz
Yes they are a good thing. They put one in a SCC project car and the thing worked great. Why do you want one though? LSD don't do **** for performance...
Old Oct 26, 2003 | 08:08 PM
plurco's Avatar
do you seriously believe that? It may not lower a quarter mile time but will greatly improve cornering and wet road performance.
Old Oct 26, 2003 | 08:10 PM
ivelweyz
There was a thread a few days ago with DAVE B and all these guys talking about acceleration and stuff and that LSD didn't do much for the MAX. Do I believe it? I don't really care. Will I get a phantom LSD when I do a swap? Hell yes...
Old Oct 26, 2003 | 08:14 PM
i guess you mean straight line performance....
cause around turns i would think it helps alot
Old Oct 26, 2003 | 08:16 PM
i dont understand why you say that its a good thing and it worked great for them but it doesnt do anything....
Old Oct 26, 2003 | 08:19 PM
ivelweyz
I was talking about straight line performance. I saw quite a few MAXIMAS do peel outs and 2 times did I see one tire mark behind them. It was always 2 straight burnt rubber lines. In the corners and such LSDs are great...
Old Oct 26, 2003 | 08:26 PM
yeah thats what i thought...what did SCC say about them?
Old Oct 26, 2003 | 09:44 PM
ivelweyz
I'll try to scan the page...
Old Oct 26, 2003 | 09:51 PM
KWheelzSB's Avatar
http://www.phantomgrip.com/
I emailed the company to find out if their specified '98+ Maxima manual tranny version of the product would work for '95-'97 models.
They do not have one spec'ed for '95-'97 manuals, but I see no reason why if it works in a '98, it wouldn't work in all 4th Gens, since the internals are the same. The quafieamerica LSD is one part# for '95-'99, so I'm not sure why this would be any different
Will let you all know what kind of response I get from them. . .
-K-
Old Oct 26, 2003 | 10:18 PM
NOMAD MAXIMA's Avatar
-K-
I'm getting mine installed in November together with my VB and torque
converter.
Old Oct 26, 2003 | 10:24 PM
Ninos_Maxima's Avatar
be the change u want2C
Originally Posted by NOMAD MAXIMA
I'm getting mine installed in November together with my VB and torque converter
converter.
TQ Converter for an auto max? Since when?
Old Oct 26, 2003 | 10:39 PM
Yes, that's right 5 speed manuals have fly wheels and auto's have torque converter's since they invented auto transmissions. All automatic's have torque converter's. Anyway when you start to shop around you will see for yourself if you wan't to go SC, Nitrous or Turbo you need to beef up that auto.
Old Oct 26, 2003 | 11:11 PM
I30tMikeD's Avatar
No, I don't believe my LSD does much for launching purposes at the track. I can feel it work when cornering, but the I30 VSLD is not a true 50/50 limited slip like some aftermarket ones. I have heard it was a 70/30, but that was just second hand info that I don't know to be true.
Old Oct 27, 2003 | 01:03 AM
Kevin Wong's Avatar
I'll have my Phantom Grip on once my clutch or tranny starts dying (I have 68K miles on my stock drivetrain). My 2nd tranny is at my friend's shop and the Phantom Grip is going to be installed this week. I have my Fidanza and Exedy Stage 1 clutch in my garage, but I want to do the install all at once. Can't wait, but I thought until I need to replace something. BTW, I went with the upgraded Green springs.
As for performance, it should totally improve the cornering, but also the straight-line. The tires should hook better instead of torque-steering all over the place. I don't know if it's a huge improvement, but I'll take what I can get.
Old Oct 27, 2003 | 04:33 AM
mzmtg's Avatar
Minister of Silly Walks
Manual + Auto both have flywheels.
Manual: clutch
Auto: torque converter
Eh...sort of....
Old Oct 27, 2003 | 04:46 AM
96sleeper's Avatar
I think I have read some bad things about it somewhere. You might try posting in the Si vs. All section of clubsi.com. It puts pressure on something and can cause it to wear prematurely I believe, as well as not working all the time. I could be wrong though.
Old Oct 27, 2003 | 06:10 AM
Stephen Max's Avatar
Originally Posted by mzmtg
Eh...sort of....
Right. The automatic engine has what's called a flex plate, which replaces the flywheel and bolts up to the crank and to the torque convertor. The flex plate is much thinner and lighter than a flywheel. The inertia of a heavy flywheel is used to smooth out firing pulses in order to make the engine idle and run smoothly. The inertia of the TC and also the viscous damping in the tranny fluid in the TC do the same in the auto tranny.
Old Oct 27, 2003 | 06:25 AM
Dave B's Avatar
Not DAVEB the parts guy
I believe the "spider" gears are what you're refering to. The Phantom Grip somehow puts loads on the spider gears which in turn makes the open differential perform like an LSD to a point. It's almost like a locker in some regards. And yes, the problems with the Phantom Grips are becoming more widespread after people have used them for a year or so. I wouldn't risk it and if I wanted a LSD, I'd invest in something like the Quafie or I30 VLSD.
The VLSD ratio is about 70/60 to 30/40 depending on conditions, clutch pack effectiveness, condition of the clutch pack fluid, etc. VLSD also takes a short time to react to the "peg-leg" spin because it takes time for the clutch pack fluid to warm up and engage the clutches. It still works okay in the turns, but in the straight line the time it takes to start working is of little benefit in the 1st 60'.
Dave
Old Oct 27, 2003 | 11:18 AM
Kevin Wong's Avatar
I have yet to hear of a Phantom Grip “LSD” user, that was properly installed with the upgraded green springs, to have any bad experiences. I’ve seen a few Saturn and Neon owners have the diff blown apart, but that was due to a weld problem only for those cars. The only other case I know of is a turbo H23 prelude that was putting down 350 whp. The whole tranny blew (from the diff) at the drag strip. It was stable at 350whp, but he increased his boost…actually there’s a video floating around of that night. Since then, he upgraded the tranny and shoved a Quaife in there. I think for my purposes, the Phantom Grip will be just fine.
I bought an extra 5-speed tranny from a 99 for only $160 shipped and my friend at a transmission shop is doing the install, so this is much cheaper than a Quaife.
Old Oct 27, 2003 | 09:17 PM
KWheelzSB's Avatar
I stand corrected. . .& educated. Thanks.
Old Oct 27, 2003 | 11:22 PM
right right.
Old Oct 28, 2003 | 05:38 AM
BEJAY1's Avatar
Conecarver
Phantom's had some good writeups on NPM including a test of straightline accel.
http://www.nissanperformancemag.com/...2/phantomgrip/
http://www.nissanperformancemag.com/...ntomgrip.shtml
I've also heard it's a sturdy product from some autox buddies - no matter which springs they've used.
Old Oct 28, 2003 | 06:44 AM
brizsblackmax's Avatar
my 95se 5 speed leaves dual solid tire strips 2 1/2 car lents rpms permitting does that mean i have vlsd? not once have i spun only one tire at a time
Old Oct 28, 2003 | 07:19 AM
Dave B's Avatar
Nope. My Maxima does the same thing. Some cars are more prone to "peg leg" launching because of torque (or lack of it), lack of weight over the tires, and unequalized axle lengths.
If you really want to test and see if you have an LSD, go around a 90 degree turn on a wet street in 1st and punch it. If the inside tire spins dramatically then you don't have a LSD.
Dave
Old Oct 28, 2003 | 02:16 PM
so in this case lsd is good for you? :x
Old Oct 29, 2003 | 06:17 AM
what the hell is NO2?
Old Oct 29, 2003 | 02:20 PM
its number 2 my second car...
Old Oct 29, 2003 | 04:45 PM
oh i see.
ef9
Aug 14, 2015 03:03 PM
Supragte
Aug 12, 2015 10:00 PM
wolfmanjack210
Oct 6, 2001 05:15 AM
LoveSick
58
Jul 23, 2001 01:36 PM
Omegasrk
Nov 8, 2000 03:34 PM
