How to rewire your fog lights - With Pictures!!
Old Feb 20, 2001 | 06:39 AM
breaux124's Avatar
Here is the link:
http://www.geocities.com/breaux124/M...fogrewire.html
I rewired my fog lights this weekend, so I took pictures and did a small write up. These directions should be used with the instructions given in the Maxima FAQs.
Old Feb 20, 2001 | 07:22 AM
fc95se's Avatar
fog lights
Bryan,
Your instructions and pics look very good. I might add one suggestion: After you re-install the corner light/sidemarker, this might be a good time to secure the light from behind. I did this by removing the fog lamps, then stick my arm through the hole to the back of the sidemarker then tighten the bolt from behind. I have heard of other people's clear corners being stolen because all you need is a screwdriver to get them out.
Also, I usually call the lamp right next to the low beam the cornering lamp. The one that you do the splicing with is the sidemarker (not to be **** or anything).
Good Job!
FC
Old Feb 20, 2001 | 07:53 AM
breaux124's Avatar
Re: fog lights
Originally posted by fc95se
Bryan,
Good Job!
FC
Thanks for the comments, I'll probably change some of the wording that I used. As for the screw in the back of the sidemarker, I figured that people with clear sidemarkers would already know to do that, but people with the normal orange sidemarkers would just pop them in and out.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
