Dealer rip-off or legit? (wheel alignment)
Old Oct 30, 2003 | 01:23 PM
Hellspawn's Avatar
Called the closest Nissan dealer today for a 4-wheel alignment price and am not sure if this place is a rip-off or not..
1997 SE
4-wheel alignment = $64.99
installation of CAMBER BOLTS on front = $68.99
Total for 4-wheel adjustment = $134.98 !
Is this legit? He was saying that it is 30 minutes per side to install these bolts..
WTF?
Any advise would be greatly appreciated.
Old Oct 30, 2003 | 01:29 PM
njmaxseltd's Avatar
Installation of camber bolts is a 5 minute job once the car is up and the wheels are taken off.
$135 is on the steep side, but as long as your car is tracking straight now, don't worry about it.
Curious, why did you need camber bolts? Is your car excessively lowered?
If it's not excessively lowered, then bad camber usually means bent suspension components.
Old Oct 30, 2003 | 01:37 PM
Hellspawn's Avatar
Hi
the car is stock springs and shocks, only mods to that area is a fstb and an rsb.
This was a quote over the phone.. Said they did one last week and it needed the bolts as well. Something about a different size bolt and none of the 96/97 models he has seen had the bolt(s).
The car has never been aligned, 73k, 1997 model.. A little bit of wear on the edges of the tires, a little pull to the right (drift) though.
I'm lost..
Old Oct 30, 2003 | 01:47 PM
big_al's Avatar
I went to NTB a few weeks ago, $60
Old Oct 30, 2003 | 01:49 PM
Hellspawn's Avatar
I asked what these magical camber bolts did and the SA said "I'm not the mechanic, but they must be pretty important"..
Can someone explain exactly what they allow for, that the car can't do now?
thanks
Old Oct 30, 2003 | 01:50 PM
TXtoTNmax's Avatar
camber
Yeah i was looking at going to an NTB cause I have used them before. The question i had was how much it should be to get my camber bolts installed? Tom says it is an easy process, so i was wondering how much so i dont get ripped off?
thanks
Old Oct 30, 2003 | 02:30 PM
Torgus's Avatar
pep boys does 4 wheels for a flat 50 bucks up here in the NE. camber bolts you got ripped on but the alignment wasn't bad...imo
Old Oct 30, 2003 | 02:50 PM
LastBoyScout's Avatar
Ahh.....camber......
Camber is the pitch of the tire either to the car (negative camber) or away from the car (positive camber). Caster on the other hand is the pitch of the front of the tire towards the car (negitive caster) or away from the car (positive caster).
Camber is important because it allows for the car to have a flat footprint.....or should i say a flatter foot print when going into a turn. Imagine your tire is completely vertical. Now notice how the tire contacts the pavement with the most availible area. Now imagine the tire has a 2° pitch to it. See how the foot print of the tire is slightly reduced, and it is more on the inside edge. When you go into a turn, the wheel straigtens out, or becomes closer to vertical, thus allowing you to grip better in the turns.
Every auto maker allows for some camber in their design. You can check your Max manual for the recommened settings. Most performance cars are set to 2° while high end race cars/rally cars (non-street) are set from 3° to 4°.
Camber is simple the setting that allows the least resistance when trying to go straight.
Its amazing what you pick up while getting merit badges.........
Hope that explains it a little better.
Old Oct 30, 2003 | 04:24 PM
Hellspawn's Avatar
So the max would do well having these bolts then I take it? Just hate to put out some $$$ if it's not necessary..
njmaxseltd: are those bolts something the average joe can install or ??
Old Oct 30, 2003 | 06:56 PM
ManualMaxima's Avatar
5th Gen till she dies!
i have a camber bolt on the passenger side front. I got cut off in the rain and slammed into a curb, i need a new steering knuckle. and the camber bolt is on for temporary. hahaha it sucks. But my car was a way out of wack and i got one camber bolt and an alignment at kuffman tires for around $65
Old Oct 30, 2003 | 07:56 PM
Stereodude's Avatar
Sounds like he hasn't gotten it done yet...
You shouldn't need Camber bolts. If you have a stock suspension (stock ride height) and you need camber bolts something else is broken/bent and should be replaced.
Old Oct 31, 2003 | 03:54 AM
true true i will vouche for that!
Old Oct 31, 2003 | 06:16 AM
the only reason to mess with the camber is as a cheap steering/handling performance upgrade. If you need the bolts, and it is at stock camber and caster.....then something else is wrong.
matts95max
Apr 23, 2025 10:44 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
dcam0326
Sep 8, 2015 11:02 PM
