coil pack help!
Old Nov 2, 2003 | 07:25 PM
mondonitro's Avatar
coil pack help!
I went to change my spark plugs and when I pulled the coil pack out it seperated between the long pencil shape and the boxy part, There was just a little spring inside, it appears the previous owner did this, it came apart with little effort, Do I need to replace it? It seems to run slighly rough now.Can it be fixed. Will it get worse? Any help thanks
Old Nov 2, 2003 | 07:51 PM
outsider's Avatar
huh? i dont get it
Old Nov 3, 2003 | 03:30 PM
kitmaxima's Avatar
that is a bad coil pack
i just replaced mine
mine was rotating between the same area
i was not get a good spark
and the engine was ticking as a result
after everything runs great
i hope this helps a bit
Old Jul 22, 2010 | 09:04 PM
roflcopter939's Avatar
no symptoms
I was just wondering what to do if I DON'T have any symptoms. I have the same problem on one of the front coil packs, it broke when I was replacing the spark plugs and I put everything back together to see if it would work. It actually ran better than it ever has (previous owner never changed spark plugs) but should I be nervous now that the coil is clearly broken. Thanks!
Old Jul 23, 2010 | 06:37 AM
cashoit's Avatar
if u got the cash, replace it. If not, then dont worry about it till u have to. You will kno when it fails, trust me.
Old Jul 23, 2010 | 07:21 AM
jholley's Avatar
That is no major issue:
http://forums.maxima.org/4th-generat...hins-fail.html
With it reassembled just wrap electrcal tape around the boot to keep it firm.
Old Jul 23, 2010 | 09:12 AM
cartman854's Avatar
Sounds like your talking about the end that attaches to the spark plug, OEM ones are sealed on with a small amount of silicone, but to remove the plugs, I pulled the little end cap thing off to get them out. Coils are cheap if you can get them used on the ORG. I get all 6 for $25 shipped, and they had less miles so I just swapped all the rear ones, and thats when I found a coil area thing, the long shiny part where the coil goes, full of oil..... Thus giving me a reason to get a MEVI and Spacers
Old Jul 24, 2010 | 06:56 PM
I think I might be there, drove it to New Hampshire last night, serious stuttering at low RPM, mostly when idling at red lights. Is there some way to reattach the spring so the stem is connected with the coil again? I just put them on top of each other and tightened the screws...
Old Jul 24, 2010 | 08:14 PM
kolbpilot's Avatar
The little research I did on Maxima before buying was learning about the next generations coil problems. I take it the 95-99 are a little better. Haven't touched mine since purchase, so far, so good.
Old Jul 24, 2010 | 08:35 PM
cdmapro's Avatar
is your CEL light on? if so, get your codes. you will likely have to replace that coil. maybe others.
Old Jul 24, 2010 | 08:38 PM
96i30azn's Avatar
just wondering, did any of you read jholley's link? it's really helpful in case you haven't
Old Jul 25, 2010 | 07:54 AM
I did actually and that's what concerns me. At the base of the coil in the picture there's enough of a nipple I guess you might call it, to attach the stem and spring to. I chagned the other 5 without removing the stem, and this one broke clear off, even the nipple. I think I just broke a good coil pack
Old Jul 25, 2010 | 12:36 PM
jholley's Avatar
I've broken that nipple off the transistor base before. Without that plastic nipple the stem won't firmly mount onto the base. I replaced it with a used OEM coil I purchased from another member.
Old Jul 26, 2010 | 07:07 AM
I think I will have to do that, I'm not ready to drop $ on six new coils yet. Thanks everyone for your answers
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
howardis
Dec 11, 2019 06:10 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
