make one touch windows
Old Nov 19, 2003 | 10:14 PM
9maximuz8's Avatar
does anyone know if u can make the 95-99 maximas windows one touch up/down like the new 2004s?? if u know, can u tell me how to??
Old Nov 19, 2003 | 10:29 PM
1FSTMAX's Avatar
Originally Posted by slammed95
Is it that hard to hold down the button?
Werd~!
Old Nov 20, 2003 | 12:48 AM
Kanaka's Avatar
it would probably require modifying the circuitry on board. if i remember correctly when i did my LED's, for the drivers side one touck, when you push down there are two pegs and two switches. one switch activates 1/2 way down for the regular down, and if you push it all the way down, it will activate 2nd switch which is the 1-touch switch. i think there was room to put a 2nd peg on the master (driver's) switch for the front passenger side. do not recall if there was room on the circuit board for a 2nd switch though. i don't think the passenger side had room for a 2nd peg or switch. nor do the rear's or even the master control for the rears...those only had room for one peg/switch. so if you really wanted to, you probably could make a 1 touch to roll front passenger window down with master switch. i don't think any had room for a 2nd peg/switch for the up side. correct me if i'm wrong, i haven't opened my switches for a while.
Old Nov 20, 2003 | 08:44 AM
climaxima's Avatar
you certainly can. you need to go to autoloc.com and buy 2 wc1000 and then wire those up.
Old Nov 20, 2003 | 04:49 PM
lilgrebbie's Avatar
If I remember corectly these are the same ones used for the one touch sunroof. Search that in the faq, I would think it sould be close to the same instal.
Old Nov 20, 2003 | 04:55 PM
SXN's Avatar
SXN
they make one touch circutry units...no big deal. a lot of people buy them for their sun roofs. you just need to buy them, and wire them into your current window switch wiring.
*edit* heres the link for the sun roof mod
http://www.vqpower.com/v2/modules.ph...howpage&pid=17
Old Nov 20, 2003 | 04:57 PM
venompwr2's Avatar
Do you mean for all of the othe windows? Because my drivers side has it
Old Nov 20, 2003 | 08:56 PM
9maximuz8's Avatar
ya my driver side has it to but i wanted to put it on the other windows
Old Nov 20, 2003 | 09:39 PM
SXN's Avatar
SXN
use the links we posted...its easy
The Frye
Feb 3, 2019 08:34 AM
rnb754
Sep 14, 2015 11:39 PM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
