High Beam Light
Old Nov 22, 2003 | 08:38 PM
Spectre's Avatar
High Beam Light
Ok I pulled out of my driveway and one of my HIDs was out and I didn't notice this till later because one alone still lights up the road but anyway I pulled over later in a parking lot and popped the hood and one of the connectors just came a little bit out. Popped it back in and the lights were rockin but now my high beam light is on and I can't do anything to turn it off. Any ideas? Thanks in advance.
Mike
Old Nov 22, 2003 | 08:56 PM
ch13f's Avatar
You probably plugged the connector into the wrong hole, the stock harness should have a black ground wire and two others next to it. You want your HID power connector plugged into the slot right beside the ground wire (it should be the one in the middle) I hope that made sense
Old Nov 22, 2003 | 08:58 PM
Spectre's Avatar
No, it's the right way because it was in the same connector the whole time because it was just a little bit loose and I pushed it in all the way.
Old Nov 22, 2003 | 09:09 PM
ManualMaxima's Avatar
5th Gen till she dies!
this happened to me tonight as well, exept i do not have a kid kit. When one of my headlights go out, my highbeam light comes on.
Old Nov 24, 2003 | 04:50 AM
Albertt's Avatar
Mike
Something has either shorted out, or you have a bad relay.
Old Nov 24, 2003 | 03:01 PM
kelvin927's Avatar
how can u put the HID and still have a high beam???????
Old Dec 2, 2003 | 09:54 PM
Spectre's Avatar
I don't have high beams. The light is the same but the high beam light is on....that's all. You can have high beam HID lights if you buy a HID kit that has it...but they cost double and not like you really need it because in our head lamps with a HID the light gets spread everywhere but does cause a problem to other drivers.
Mike
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
