Car won't start
Old Nov 24, 2003 | 10:33 AM
SLOW96MAX's Avatar
Car won't start
I have a problem with my car. It doesn't start some times. I t turns over but it just won't start. Any takers?
Old Nov 24, 2003 | 11:14 AM
dss42's Avatar
when was the last time you changed battery?
Old Nov 24, 2003 | 11:15 AM
dss42's Avatar
It could be battery,starter, bad ground connection from engine to tranny and many other things when did this start how often?
Old Nov 24, 2003 | 02:25 PM
SLOW96MAX's Avatar
[QUOTE=dss42]It could be battery,starter, bad ground connection from engine to tranny and many other things when did this start how often?[/
QUOTE]
It started recently. The funny thing is the next day it started fine. How could it be the starter if it turns over but won't start. I always thought if it was the starter it would make a whinning noise and/or not even turn over.
Old Jan 28, 2008 | 10:01 PM
scrubby510's Avatar
I have a similar problem...my 95 maxima se will have trouble starting, itll take a few cranks before itll start and then the car will run fine...but last few mornings it's gotten worse. Now the car won't crank, but all the interior lights, headlights, and radio still work. Is it a faulty battery? fuse?
I've tried a jumpstart and that didn't work, but 5 minutes after I took the cables off...the car started perfectly fine.
Old Jan 28, 2008 | 11:32 PM
kaneda_77's Avatar
Scrubby - consider replacing your cables or at least the terminal connectors(if they're corroded).
Slow96max - It's most likely not your starter. I'd check your plugs and coils... you'd be surprised what that will do for you.
keep us posted
Old Jan 28, 2008 | 11:38 PM
97_Roadrunner's Avatar
Could it be related to the crankshaft pos. sensor?
Old Jan 28, 2008 | 11:45 PM
MaxGordon7's Avatar
ive heard the coolant temp sensor before on this problem.
Old Jan 29, 2008 | 03:44 AM
whlimi's Avatar
Get a digital multimeter and check the voltage when the car doesnt want to start. Also check it when the car is actually on. See if your readings are within normal range. I had a similar problem with an alternator that was about to crap out. Do a voltage check under load (heater on full, defroster on, all lights on, radio on) and see what the voltage is.
Old Jan 29, 2008 | 05:35 AM
TunerMaxima3000's Avatar
For fuak sakes man, search before you post.
http://forums.maxima.org/showthread.php?t=338918
http://forums.maxima.org/showthread....ighlight=start
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
