Side Marker Lights - 95
Old Nov 24, 2003 | 11:19 AM
jguillory's Avatar
Has anyone replaced the side-marker bulbs on a 95-96? I replaced both with #194, but cannot get them to light. Don't think there is a fuse controlling only those two lights.
Any other ideas?
Old Nov 24, 2003 | 11:30 AM
clee130's Avatar
So you didn't check the fuse yet? If changing the bulbs didn't work, why not try checking the fuse?
Old Nov 24, 2003 | 04:36 PM
Capital15's Avatar
Side marker??? or clearence lights???
Old Nov 24, 2003 | 07:56 PM
MaximaEvolution's Avatar
the only lights on the outside of the maxima that uses 194 bulbs are the side marker lights on the bumper, underneath the clearence lights.
Everything else works? If everything else works exept for those two lights (one on each side) then the only logical answer that i can come up with is that the wire is no good. But then again, could the wire go bad on both sides? Check all of your fuses anyway.
Old Nov 25, 2003 | 01:25 AM
MIXXMAX's Avatar
Get a multi-meter and see if voltage is running thru the wire. If not, there is a short somewhere.
vingodine
45
May 21, 2016 12:46 PM
iflexsteel
Sep 15, 2015 03:37 AM
rtirbany
Sep 8, 2015 11:46 AM
98nismomax
Aug 13, 2015 12:44 PM
papo99
Aug 9, 2015 07:32 AM
