around the headers i see little marks of oil ?
Old Nov 25, 2003 | 09:28 AM
dss42's Avatar
Its like something is leaking from the gasket?? like right under the screws I see black oil stains basically I am wondering if it is a problem if I drive like this and what may have caused the problem?
Old Nov 25, 2003 | 09:32 AM
ejj's Avatar
ejj
Are you sure it isn't the gasket itself? IIRC there are black tabs that stick out.
Oil wouldn't be coming out of the headers, or you've got a big problem. Check that the valve cover isn't leaking. I had a valve cover leak, and the oil would make its way down to the headers and start smoking...at first glance it would look like something was leaking from the headers, but that obviously wasn't the case.
Old Nov 25, 2003 | 09:36 AM
dss42's Avatar
Well when i looked at it I thought that the gasket inside the headers might of rip or something and its causing some oil to come out not alot i dont see any spills its just very little stains..
Old Nov 25, 2003 | 09:39 AM
dss42's Avatar
I will take a few pictures and show you exactly how it looks.
Old Nov 25, 2003 | 01:21 PM
kenji's Avatar
I've had a headgasket leak on different cars, the leakage can get pretty bad, eventually covering large areas of the engine bay
Old Nov 25, 2003 | 01:32 PM
dss42's Avatar
how much is a new gasket usually?
Old Nov 25, 2003 | 01:47 PM
kenji's Avatar
33.99 each from carparts.com
there's both a left and a right, but you must find the source of the leak before you start buying stuff
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
05RLS2
Apr 14, 2016 11:49 AM
Socalstillen
Sep 26, 2015 12:01 PM
