Why is the e-brake light on?
Old Nov 25, 2003 | 10:16 AM
Max-2-GTR's Avatar
Of course I know that when the e-brake is pulled that the light is on! but my e-brake isn't pulled and the light's still on...What does it mean? Is there a prob with the brake or it's the light that is broken?
Old Nov 25, 2003 | 10:22 AM
95bluse's Avatar
Is that that the only light on? Could be the switch is stuck or your alternator is going bad. The e-brake light doubles as a warning light in combination with the battery light. Check the switch...if that's ok..check out your charging system.
Old Nov 25, 2003 | 10:38 AM
Max-2-GTR's Avatar
Which switch do you mean?
Old Nov 25, 2003 | 10:41 AM
mzmtg's Avatar
Minister of Silly Walks
You are low on brake fluid.
Old Nov 25, 2003 | 10:42 AM
Max-2-GTR's Avatar
You mean brake fluid for the e-brake(if that exist) or for the normal brakes?
Old Nov 25, 2003 | 10:49 AM
mzmtg's Avatar
Normal brakes. The parking brake is cable operated.
Old Nov 25, 2003 | 10:53 AM
voltman's Avatar
Yup, brake fluid. Check your pads too. If they're thin enough, the amount of fluid in the reservoir will be much less.
Old Nov 25, 2003 | 10:55 AM
Max-2-GTR's Avatar
How do I refill the brake fluid? Is it a DIY job?
Old Nov 25, 2003 | 11:00 AM
Shadow's Avatar
Yeah. Open your hood, find the brake fluid reservoir on the driver's side firewall. It's really obvious because it's on top of the master cylinder. Check the level,and if it's low, just add a little fluid. I think our cars take DOT3. It literally takes seconds.
outsider's Avatar
you put the dot 3 brake fluid through your resvior
Old Nov 25, 2003 | 11:01 AM
Max-2-GTR's Avatar
That's it? That's great, thx guys for the quick replies.
Shadow's Avatar
Oh, I forgot. On my car, sometimes in cold weather, the parking brake cable would stick and cause my brake light to stay on. I would have to work the lever a little bit to trip the sensor enough so it would know the brake was no longer engaged. Only happens in cold weather on my car though. That may be your problem if your brake fluid isn't low and you've ruled out all other problems.
Old Nov 25, 2003 | 11:03 AM
Max-2-GTR's Avatar
That's maybe why too cause I live in canada and sometimes it get freakin' cold but I've never encountered this prob before, but I'll check that out too. Thx
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
