Eibach, H&R, or Tein?
I'm having a difficult time deciding on which springs to buy. I hear that the Eibach Pro-Kit is one of the stiffest springs available, H&R Sport springs are supposedly one of the softest yet has a higher spring rate than stock. I'm very interested in the Tein's but haven't heard or seen too many pics of them installed (hint hint, please post them if you have em). Also I don't wanna go too low because I don't wanna deal with all that camber problem and etc.
Any suggestions or input would be helpful, thanks all.
B
B
Tein's may require camber bolts and may be a bit low for the gr-2's to handle for a long period of time.
I have Eibachs, and yes they are stiff. The drop is noticeable to any max owner, but don't expect people to think your car is lowerd.
I wasn't really looking for looks, but more for performance and comfort at the same time because the other day I was on the highway with construction making a turn and lost control for a few seconds. After fish tailing about 3 or 4 times, i finally gained back my traction in the narrow road. SCARRRRY.
Teins provide the nicest drop of any spring. They're stiffer than H&Rs, but not as stiff as Eibachs. I've only heard rave reviews about Teins. I'd pair them with AGXes, Konis or Illuminas though. That goes for the Eibachs as well. If i had to get anything, an Illumina/Tein combo is top of my list. However, it looks like i'm going to have a JIC coilover setup....and that's the holy grail...albeit way more expensive...
Originally Posted by nick
I like the stance of your car. How is the ride? How does it compare to a stock SE ride?
Thanks for the pictures,
Gears
Pic of a 4th Gen on tiens (I can't remember his maxima.org SN right now)
http://drewm.dyndns.org/~drew/pics/g...scaled_640.jpg
That was taken at the pre-Stillen meet.
Originally Posted by takentomax
Check these out!
Before H&R (stocks):
As I understand, KYB-GR2 last only with H&R (on the good roads). For anything else I would need AGX, Illuminas etc.
I will get GR2 I belive, cannot really afford anything more expensive..
Heres a coupla pics of my setup, im running B+G sport springs...
As far as "perfect" drops, Teins are by far the best springs to go with. You will have to careful about camber as well as paring them with the best and most aggressive struts available (Koni inserts, Illuminas, AGXs). GR-2s IMHO, will only cut it with B+G, H&R, progress, maxspeed, and eibach.
Eric
Eric
Originally Posted by Maxima97'SE
Hey 1FSTMAX, whats your suspension set up it looks decently low?
BTW check my homepage.
I've got Eibach Pro-Kit with Tokico Illuminas. If this is harsh, I can't imagine what comfortable is. The ride is amazing tight and comfortable. It's probably the total effect of the whole package.
Originally Posted by 1FSTMAX
Looks stock, where is the drop?
imported_Nismo_max
Feb 17, 2016 03:39 AM
morteljc
Oct 19, 2015 10:47 AM
Ben2003GLE
Sep 24, 2015 04:25 PM
