Problem With Eibach And Tokico
Old Nov 26, 2003 | 10:23 AM
BDezMax's Avatar
i recently bought the eibach springs along the tokico blue struts. after they were installed, i ran into a problem that no one seems to have the answer for. When i turn the wheel, either sharp or just making a right or left on a side street, when i straighten the wheel back out, it gets "stuck" to the side that i just turned "kind of like my alignment is off" but then if i turn the other way, it then gets stuck that way!!
someone please help me and tell me whats wrong.
Old Nov 26, 2003 | 10:56 AM
Gears & Crosses's Avatar
Just a quick guess...
It sounds like you have way too much castor. If your not familiar with this term, it refers to an alignment specification. Do the front struts look like thay are set too far back (towards the back of the car) at the top? Double check your strut installation on the front.
Hope this helps,
Gears
Old Nov 26, 2003 | 11:23 AM
Look closely at this thread: http://forums.maxima.org/showthread.php?t=266281
Sounds like an alignment problem?
Hope this helps,
Gears
Old Nov 26, 2003 | 11:35 AM
D1NOnly34's Avatar
I have same setup, never experienced that problem =P
Old Nov 26, 2003 | 12:53 PM
BDezMax's Avatar
i had an alignment done, and everything is within the ratio it should be.
Old Nov 26, 2003 | 01:52 PM
drewm's Avatar
I'd say your installer must have put something back together wrong. Sounds like a strut bearing issue. I have never heard of anyone with that problem.
Old Nov 28, 2003 | 06:24 AM
carlmax5's Avatar
I have exact set-up - Eibach/Tockico (blue) Razo in Milpitas California did mines No Problem-Runs Perfect! I feel sorry for you dude. i hope problem gets resolve.
Old Nov 28, 2003 | 08:04 AM
PedalKick's Avatar
I had a similar problem after my Accord had work done on the suspension
after my son ran it into a curb. They replaced a couple of parts but
neglected to tighten at least one nut. This nut backed off over time
and the suspension became sort of loose. If I accelerated, it would
pull to one side, and when decellerating, it would pull to the other side.
Check that all fasteners are tight and observe the action of the
front suspension as someone turns the wheel back and forth while
the car is stationary to see if anything is shifting. It could even be
a loose steering rack.
Old Nov 28, 2003 | 08:05 AM
Dave B's Avatar
Not DAVEB the parts guy
Sounds like the strut bearings weren't put back in and/or they weren't put back in correctly. Did you have a "Honda" shop put these in?
Dave
Old Nov 28, 2003 | 11:20 AM
tzmanles's Avatar
I have the same Eibach/Tokico Blue's, no problems here
imported_Nismo_max
Feb 17, 2016 03:39 AM
Peter Paul
Jan 2, 2016 05:18 PM
homewrecker
Sep 24, 2015 07:01 PM
ajahearn
Sep 19, 2015 03:03 PM
