Transmission sensor cracked.. how bad is that?
Old Nov 26, 2003 | 07:30 PM
Ladzio's Avatar
When I was changing CV axles 2 weeks ago, I was checking tranny (5sp) for leaks and found that transmission sensor is cracked in the spot where it's being held with a bolt. So now it is not held with a bolt obviously at all, but I did not see it leaking. However I am getting more concerned that it may fall out on one nasty bump and ruin transmission, which will be left without oil.
Here is the pic with a spot marked where it's cracked. (Borrowed from StygianMax's Nissan: 'DigiMax' page).
Old Nov 26, 2003 | 08:47 PM
matty's Avatar
Change it out if it looks bad...
-matt
Old Nov 26, 2003 | 10:01 PM
PedalKick's Avatar
Put a large washer under the bolt to overlap the
other part of the sensor
Old Nov 27, 2003 | 04:19 AM
Ladzio's Avatar
That's a good idea, I did not think of that, will definitely try that out, just out of curiosity, how much is a new one?
Old Nov 27, 2003 | 11:38 AM
skeelo34's Avatar
You should be fine. mine had been cracked for ages. Just look occasionally to see if it moved, it shoudlnt, It takes a small hammer to pop it out from the inside, so i doubt it would fall out.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
