? about jwt ecu
Old Nov 27, 2003 | 10:43 PM
raiker's Avatar
? about jwt ecu
i have read that a couple people have there rev limiters raised to 7200 but on cattmans website it say it only raises it to 7000.i was just wondering if it is an option to get it raised higher then 7000 or are u guys using a didfent ecu.thanx for any info
Old Nov 27, 2003 | 11:13 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
When you send it into JWT, you can ask for a 7200 rpm redline. But I think you have to sign a release form for that.
Old Nov 27, 2003 | 11:21 PM
I30tMikeD's Avatar
I don't know about going through cattman, but I went through JWT and had to ask for the 7200. They don't make you sign off on anything because they are not responsible for something going wrong anyhow. Of course they advised against it but I insisted.
Old Nov 27, 2003 | 11:26 PM
raiker's Avatar
so i wont need to build the engine up at all if i raise it to 7200.and is it any cheaper to go through jwt then cattman. also i remember you telling me that it took 10 weeks to get it back from jwt cattman said they will have it vack in 8 weeks.o yea one more ? is it more money to go with the 7200 redline?thanx
Old Nov 28, 2003 | 05:55 AM
Ceasars Chariot's Avatar
Old Maxima Legend
cheaper to go thru cattman, you want the 7200 just tell them thats what you want
Old Nov 28, 2003 | 07:27 AM
I30tMikeD's Avatar
No. Your stock valve springs should hold up fine. Mine have.
It's more expensive to go through JWT.
Cattman does not know how long it will take, he is just guessing. JWT takes their time and they really don't car about deadlines. Being that peak race season is over, it make not take too long. It is well worth the wait though.
7200 does not cost any more.
Old Nov 28, 2003 | 08:58 AM
krismax's Avatar
Father of the 00 VI
I wonder if 7400rpm just in first would be too much? Ill be sending one soon to JWT . I want between 7300 to 7500 .
Old Nov 28, 2003 | 09:15 AM
I30tMikeD's Avatar
Two things. From what I know, anything above 7200 might be pushing the limits of the valve springs and you may get valve float. Too much valve float and good bye engine. Also, cartest done with the VI and raised rev limiter stop seeing gains above a 7200 rev limiter and the difference between the 7000 and 7200 is minimal. I just got the 7200 so I would not have to worry about hitting the fuel cut off. If you look at the dyno graph of a VI VQ30de power just levels off after 6K, it does not fall or rise. Now if you can figure out how to keep that HP curve rising then a 7500 rev limiter might do you good. Cams may do that for us but who really knows. If you could get your power to keep climbing after 6K and went with the a 7500 fuel cut off then you would definately have to get stronger valve springs. So unless you plan to do a little bit cam and valve spring work there is no need for anyting above a 7200 rev limiter
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
t6378tp
Sep 29, 2018 04:27 PM
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
