Just got back...14.26@97mph in the automagic
Old Nov 29, 2003 | 12:54 AM
96sleeper's Avatar
I am too tired to post all the details right now, but I got a personal best 1/8 mile, 1/8th mph, and 1/4 mile. My top end was off tonight for some reason so my 1/4 trap was lower than before even with more mods now. When I get that sorted out I think I can run a 14.0-14.1 @ 99+mph because there is still some left in the car. My best two slips were:
60ft: 2.195
1/8: 9.221
mph: 79.44
1/4: 14.287
mph 97.50
60ft: 2.208
1/8: 9.254
mph: ...
1/4: 14.261
mph: 96.90
Check out that 1/8th mile mph, I think it is the highest I have seen out of any N/A 4th gen , manual or automatic. My previous best was a 14.44@98.19mph. Tonight I was only gaining 18mph from 1/8th to 1/4 mile, which is a little lower than expected. I was gaining around 20mph before. I will post more details tomorrow.
Old Nov 29, 2003 | 01:02 AM
SXN's Avatar
SXN
god DAMN...that is amazing. Good job, and especially in an auto. What mods are you running man?
Old Nov 29, 2003 | 05:24 AM
erty67's Avatar
Decal Specialist
Old Nov 29, 2003 | 05:29 AM
Kevlo911's Avatar
Kevlo for President
WOW that is FAST, u must tell us ur mods
Old Nov 29, 2003 | 06:02 AM
apbrian112's Avatar
quick question... how do you launch? trying to get me 1/4 mile times down some.
Old Nov 29, 2003 | 07:19 AM
Ceasars Chariot's Avatar
Old Maxima Legend
WHAT THA ? AMAZING !!
What mods, nice 60's, are you all motor ? Anyhoot that max can scoot !
Old Nov 29, 2003 | 08:40 AM
Maximum96's Avatar
what r your mods??
Old Nov 29, 2003 | 08:43 AM
Jepht20's Avatar
Custom User Title...
in his profile: "JWT intake, cattman SS Y-pipe, JWT ECU, B-pipe, G-force ecu, FSTB, RSB, MEVI "
awesome times man!
Old Nov 29, 2003 | 08:59 AM
Kevlo911's Avatar
Kevlo for President
awesome times man!
WTF
Old Nov 29, 2003 | 09:18 AM
96sleeper's Avatar
OK, here is my mods list.
This is what I ran at the track when I ran a 14.44@98.19mph.
G-force ECU
Variable intake
Hybrid JWT Intake
Cattman SS Y-pipe
test pipe
B-pipe (non-mandrel 2.5)
Hooker Muffler
Bullet muffler (resonator)
RVM Underdrive pulley
FSTB
RSB
Don's VB Mod
stock 15" wheels with 205/50-15 kuhmo tires.
B&G Lowering Springs
KYB AGX
added since since last track visit:
JWT ECU
70mm Pathfinder TB
Lightweight battery
Larger K&N Filter
other small weight removal (heatshields, etc.)
swapped in Unorthodox racing pulley for my leaking RVM pulley.
Old Nov 29, 2003 | 09:24 AM
ZuMBLe's Avatar
Larger filter? Are you still using the JWT intake? I can't imagine the car needing a larger filter than what comes with the JWT Pop Charger. It's 6 inches in diameter damn it. =P Great times. I think my A/T solenoids are dead. I've never had great shifting with my Don's VB mod. The car shifts faster at part throttle than WOT.
ZuM
G-force ECU
Variable intake
Hybrid JWT Intake
Cattman SS Y-pipe
test pipe
Hooker Muffler
FSTB
RSB
Don's VB Mod
KYB AGX
JWT ECU
70mm Pathfinder TB
Lightweight battery
Larger K&N Filter
Old Nov 29, 2003 | 10:00 AM
Old Maxima Legend
where did you buy the lightweight battery ? was it an odyessy.. in looking right now for 1 !!
Old Nov 29, 2003 | 10:07 AM
aznsap's Avatar
wow, is the pathfinder throttle body a good upgrade?
Old Nov 29, 2003 | 10:08 AM
luckee2bhere's Avatar
GOOD JOB BUD!!!
sweet ****....why did you swap your Gforce for JWT??? just curious....
Old Nov 29, 2003 | 10:35 AM
96sleeper's Avatar
I got it on closeout, its a hawker battery. Same as a dyna-batt without the high price. It was pretty cheap, I will try to find the site that I bought it from and send you a pm.
Old Nov 29, 2003 | 10:36 AM
96sleeper's Avatar
Originally Posted by luckee2bhere
GOOD JOB BUD!!!
7000rpm redline. The g-force was great but with the MEVI I needed more rpm to take full advantage of it.
Old Nov 29, 2003 | 10:44 AM
RA030726's Avatar
I'm nutty for Nissans
<------- JELOUSE! Congratulations on the terrific times.
Old Nov 29, 2003 | 11:46 AM
skiboarder72's Avatar
very nice run!
Old Nov 29, 2003 | 11:56 AM
1FSTMAX's Avatar
Nice times!
Old Nov 29, 2003 | 12:26 PM
I30tMikeD's Avatar
That 1/8 mile trap is simply amazing. Maybe your VI was not activating in second or third??? Do the autos hit 3rd in the 1/4 mile? Anyhow, I used to have a harlan and it would open in 1st, 2nd, but not 3rd most of the time. I pick up 21mph sometimes 22mph in the second 1/8 with my JWT-ECU and VI. I am very impressed with that 1/8 trap!!!!
Old Nov 29, 2003 | 01:02 PM
BSwithTF's Avatar
Sweet times man!
Old Nov 29, 2003 | 01:58 PM
mrnock's Avatar
96sleeper's Avatar
I have been racking my brain as to why my mph fell off on the top end. I am near redline in second right as I am crossing the 1/8th mile mark with my smaller tires. My VI just opens in third gear as I am crossing the 1/4 mile mark. I have a LED wired that lets me know when it is opening correctly. I had my VI set at 5000rpm and I trapped 97.xx 4 times in a row. I changed it to 5300rpm and my traps fell to high 96mph speeds. I think that my knock sensor may be pulling timing in 3rd gear and causing the mid range to suffer there. I also have the pathfinder TB and ran it for the first time. My A/F ratio could be screwed up because of it, or maybe the JWT ecu is just not as strong as the G-force besides the higher redline. I still have it in the car, I should have plugged it in to see if there was any difference. It is weird that 1st and 2nd gear are fine since my 60 ft and 1/8th mile were good, 3rd gear just seems to drop off. One other reason could be that is was pretty cold and tracton was no good. I was spinning most of the way through first and into the shift to second. I thought that spinning was usually good for mph, just not ET? I am still trying to figure it out. I plan to dyno soon and get my A/F ratio checked out. Any more ideas?
Old Nov 29, 2003 | 02:04 PM
96sleeper's Avatar
Originally Posted by mrnock
I don't brake torque at the line which is what most people will tell you what to do. I do a small burnout to clean off the tires. I stage and then on the 3rd yellow, I give it gas for a split second as I am still on the brake. It is almost like both feet are moving at the same time. gas pedal going down, brake pedal moving up. It is hard to explain, but it is called "flashing" the torque converter. Instead of brake torqueing you are trying to get the converter to catch right as the car is starting to move. When you "shock" the torque converter like this it lets you leave the line at a higher rpm faster. Hope this helps, it is hard to explain.
Old Nov 29, 2003 | 02:15 PM
RA030726's Avatar
interesting
Old Nov 29, 2003 | 03:17 PM
XeroX's Avatar
Hella internets
nice times... kinda brings up my faith in my auto
Old Nov 29, 2003 | 04:57 PM
Dave B's Avatar
Not DAVEB the parts guy
Congrats and wicked times as usual
Did you run octane higher than 93? The reason I ask is both Mike and myself have run higher octane and have gotten some good results. Overall, on the days I've ran race gas I've usually been my quickest. I did run my best without race gas, but my MPH seem to have suffered a bit in the topend. That day my best was almost 98mph. With race gas I've done as high as 99.5mph. Overall I usually gain high 20mph in the final 1/8th without race gas and high 21s with race gas. My highest is 22mph which is an incredibly strong for an NA motor.
Try a mix that brings octane up to around 95-96 and see how you do. I'm starting to believe that the JWT ECU may advance timing quite a bit and if you don't put some higher test gas in there, the longer gears may experience more detonation and knock retard. Many of us are running higher mileage motors which means our compression is probably more like 10.3-10.4:1 instead of the factory 10.1:1 because of carbon build-up in the compression chamber. Higher compression = more power, but also = more detonation.
I was going to go to the track tommorrow, but the station I get 100 octane from is closed on Sundays and tommorrow is the last race day of the season. It's going to be 55, sunny, low humidity, and good pressure
Dave
Old Nov 29, 2003 | 08:20 PM
Nealoc187's Avatar
SLOW
Sweet times Get a TC and slicks and stop mucking around in the 14s and run some 13s.
P.S. My fastest 1/8 mile trap speed doesn't begin with a 7
Old Nov 29, 2003 | 08:30 PM
96sleeper's Avatar
Dave
Dave, I bought a bottle of octane booster that said it would boost up to 20 points in 10 gallons of fuel. 20 points=2 octane rating so I was possibly running 95 octane, especially since I put it in 4 gallons of fuel. Other than that I am still stumped about my trap speeds. I am not as happy as I should be about a new personal best because trap speed is more important to me than ET anyway. I honestly thought I would see some 99mph and maybe even eek out a 100.xx mph trap. Any other thoughts on the loss of speed?
Old Nov 29, 2003 | 08:37 PM
Nealoc187's Avatar
SLOW
The trap speed is always the first thing I look at on my timeslip too. ET just shows me whether or not I fcked up, trap speed shows me if my car is running right. What RPM switch are you using.
Old Nov 29, 2003 | 09:06 PM
deezo's Avatar
60ft: 2.195
1/8: 9.221
mph: 79.44
1/4: 14.287
mph 97.50
60ft: 2.208
1/8: 9.254
mph: ...
1/4: 14.261
mph: 96.90
HEHEHE!!!! This is good stuff! Congrats!!!!!!!!!!!!1
Old Nov 29, 2003 | 10:37 PM
Nismo87SE's Avatar
In that case your going to have to go the toulene, xylene method. I hope you have access to some DR's or borrow some slicks, it would be nice to run that elusive 13.9 on the last race day
Dave
Old Nov 29, 2003 | 11:58 PM
Aaron92SE's Avatar
NWP Engineering.com
Whoa! Very nice! Keep it up man.
Old Nov 30, 2003 | 06:49 AM
96sleeper's Avatar
I am using the Harlan switch, but it has never given me problems since I got rid of the relay a long time ago. I have a LED rigged up in the cabin to let me know if the MEVI is opening and the light came on every time.
Old Nov 30, 2003 | 07:09 AM
I30tMikeD's Avatar
I would bet it's the lack of race gas and the 70mm TB. I would not trust those octane boosters to give you much. The TB could very well be throwing your AF wacky. Is it possible that your LED would light up when your desired rpm is reached but the harlan still flaking out? If you think it is possible I suggest checking the switch after drive when the VI is activated a few times. If it flakes out it will be blinking at you. Don't turn the car off before you check it, it will reset if you do.
When I did not use race gas I was only gaining 18-19mph in the second 1/8 mile
Old Nov 30, 2003 | 07:41 AM
96sleeper's Avatar
I guess that could be it. I never used race gas with my g-force ecu and I never had any problems, but maybe the JWT is different since it goes to 7000rpm. I am still going to try to dyno in the next few weeks and see if everything is normal.
Old Nov 30, 2003 | 01:31 PM
SXN's Avatar
SXN
I think its the new throttle body, not the new ECU
Old Nov 30, 2003 | 07:50 PM
Nealoc187's Avatar
SLOW
In what way is your MEVI LED hooked up. Is it just running off the RPM switch or is it physically hooked up to your MEVI so that when the bar swings open, the LED illuminates? My harlan though it was working fine, the switch was lighting up at the right RPM (which could be the same situation you are in). All indications were that the switch was opening fine, light was working, etc. Only way I knew it wasn't is that I was slow and when I popped the hood and tested it. The light will illuminate but my MEVI wouldn't open.
Old Nov 30, 2003 | 08:21 PM
Dave B's Avatar
Man, I must be the only guy with a MEVI that can hear his MEVI open in 2nd and 3rd gear. On my car there's a pretty substainial change in the intake tone at an indicated 5500rpms (5400rpm switchover).
Dave
Old Nov 30, 2003 | 08:30 PM
Nealoc187's Avatar
SLOW
Dave
I can't hear it open. At 7k rpm I can tell whether it is open or not because of the tone, but I can't detect a tone change right when it opens.
