New to brakes...will this fix my squealing?
Old Nov 30, 2003 | 04:54 PM
WillMax95's Avatar
My brakes squeal so loud and so much. Will changing the brake pads fix this?
Old Nov 30, 2003 | 06:23 PM
Jatan's Avatar
Change the pads and get a new hardware/shim kit. Mine is squealing because of a seized caliper
Old Nov 30, 2003 | 07:54 PM
Kashoggio's Avatar
resurface the rotor as well
Old Dec 4, 2003 | 07:19 PM
WillMax95's Avatar
anyone used the hawk brake pads from custommaxima.com?
Old Dec 4, 2003 | 07:51 PM
SXN's Avatar
SXN
sounds like the squeeler bar on the break pads (also called wear bar, etc) Its a sign you need new pads.
Old Dec 4, 2003 | 08:38 PM
zarf747
if the pads not down to the wear bar, just put some caliper lube on metal parts of the pads that are touched by the caliper and bracket. just to state the obvious, don't lube the pads themselves just the metal backing
Old Dec 4, 2003 | 08:48 PM
SXN's Avatar
SXN
unlubbed pads is not as much of a squealing noise they kinda grind more
Old Dec 4, 2003 | 09:58 PM
ABK's Avatar
ABK
Yeah I bough the car they squeeled like *****es. So I replaced my brakes, hardware and all four rotors because they were warped and it fixed the problem. But don't be a dip**** like me and don't buy metalic brakes because your friend told you because they fade like *****es. I think I will have to buy some ceramic in couple of month and replace them again.
Old Dec 4, 2003 | 10:44 PM
SXN's Avatar
SXN
yea. more metal in the pad, heats up, and fades
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
