Bolts to remove rear rotors?
Old Dec 1, 2003 | 08:07 PM
Bmr4life's Avatar
What size are they and can I get them from Home Depot? thanks
Old Dec 1, 2003 | 08:46 PM
ABK's Avatar
ABK
I pulled them off by hand, front rotors are *****es.
Old Dec 1, 2003 | 08:47 PM
Bmr4life's Avatar
Originally Posted by slammed95
Simply tap the rotor with a rubber mallet, or a hammer and a folded rag.
i read that sometimes that does work and I dont' want to be half way through replacing my rotors and end up having to get the bolts anyway. I'd rather just have em ready, but thanks.
Old Dec 1, 2003 | 08:48 PM
Bmr4life's Avatar
also, i'm not sure if my rear rotors have ever been changed so I just wanted to be sure.
Old Dec 1, 2003 | 08:57 PM
ABK's Avatar
ABK
get a rubber hammer, I tried using the bolts on front rotors I stripped 3 of them somehow. Just hit couple times and turn the rotor and hit it some more
Old Dec 1, 2003 | 10:26 PM
Bmr4life's Avatar
The rotors will come off easier by tapping them. Rust is holding them on, and the bolts may not exert enough force to break them loose.
If you're not gonna reuse the rotors, hit the rotors directly with a hammer. It will come off.
aight, thanks everyone. since i definately will not be reusing the rotors, i guess there is no reason not to just bash them off with a mallet or hammer. thanks again
Old Dec 2, 2003 | 08:51 AM
twiggy144's Avatar
M8 bolts for rear rotors, M10 bolts for front rotors. Dont use imperial size bolts, even if they "look" same thread and size, else you will ruin the treads of the rotors.
or was it M6 rear and M8 front ? Nah.. pretty sure M8 rear and M10 front.
Old Dec 2, 2003 | 10:25 AM
UncleMax98's Avatar
Don't bash the rotor too hard or the wheel bearing life may be shorten.
Old Dec 2, 2003 | 10:27 AM
Jeff92se's Avatar
I'm needing a caw
Coat the backs of the new rotors with antiseize
Old Dec 2, 2003 | 12:13 PM
PoePoe2797's Avatar
I tried banging the rotors thinking it would free it.....the rotor didn't budge. I used the screw to press it out and it came of real easy
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
