Sounds like a diesel?
Old Dec 3, 2003 | 06:14 AM
mzmtg's Avatar
Minister of Silly Walks
When my car is cold in the morning, it sounds like a diesel. Only at light throttle between 2k and 3k RPM. If I give it a little more throttle, it smoothes out. It only does this when it's cold.
Any ideas on what this might be and how to fix it?
Thanks.
Old Dec 3, 2003 | 06:34 AM
ABK's Avatar
ABK
knock sensor, or chain tensioner or some other sensor
Old Dec 3, 2003 | 08:08 AM
mzmtg's Avatar
KS is relatively new.
Tensioner may be an issue.
No codes for other sensors.
Old Dec 3, 2003 | 08:11 AM
ohannon7's Avatar
mine sounds more deep and rumbly in the moring. i thought it was b/c it was cold and grumpy
Old Dec 3, 2003 | 08:31 AM
PoePoe2797's Avatar
Same hear but only until it starts warming a little
Old Dec 3, 2003 | 10:16 AM
ABK's Avatar
ABK
I guess same over here now, just started. It doesn't grone but it kicks back a little just when it's called. I had all my fluids replaced so I guess it's normall. Also it only does it when I sit still
Old Dec 3, 2003 | 11:27 AM
Rowan's Avatar
Thanks.
Mine does it too. No idea what it is. Mine is a raw sounding noise between 2500-3000 but smoothes out above that and when the car is completely warm.
-R
Old Dec 3, 2003 | 12:39 PM
GoalieKeg's Avatar
Mine too, but it does it sometimes when the car is warm too.
But my exhuast is friggin loud with the y-pipe.
Old Dec 3, 2003 | 12:42 PM
Jeff92se's Avatar
I'm needing a caw
Hmm how's your oil pressure?
Old Dec 3, 2003 | 12:55 PM
mzmtg's Avatar
The light doesnt come on...other than that I have no idea.
Old Dec 3, 2003 | 01:03 PM
Jeff92se's Avatar
I'm needing a caw
This is just a wild guess but if you have low oil pressures when you first start the car, you might get some noises from the chain tensioners or maybe some main bearing noise from the crank? Could be a host of things really.
Old Dec 3, 2003 | 01:11 PM
Kevlo911's Avatar
Kevlo for President
i have same prob but it lasts 2 sec RIGHT WHEN I START. it has happened a few times only in COLD weather
Old Dec 3, 2003 | 01:22 PM
mzmtg's Avatar
No, my noise (or roughness) occurs when driving, not at startup. When I accelerate lightly I get the diesel-like noises from 2000 - 3000 RPM. More throttle or more RPM makes it go away.
Old Dec 3, 2003 | 01:39 PM
Kevlo911's Avatar
Kevlo for President
what kind oil and filter do u use?
Old Dec 3, 2003 | 02:03 PM
mzmtg's Avatar
Bosch & Castrol GTX 10w30
Old Dec 3, 2003 | 02:05 PM
Jeff92se's Avatar
I'm needing a caw
Well off hand, it sounds like piston slap. Never heard anyone else having it though.
Old Dec 3, 2003 | 02:38 PM
nick's Avatar
have the same problem , i pin-pinted the source to EGR valve or EGR back pressure transduces valve
it is an exhaust leak for sure.
once the metal gets worm and expands - noise goes away.
Nick
Old Dec 3, 2003 | 04:15 PM
Kevlo911's Avatar
Kevlo for President
it may be time to replace ur timing chain tensioner
these MIGHT help
http://forums.maxima.org/showthread....t=timing+chain
http://www.rpmrons.com/nissantiming.html
Old Dec 3, 2003 | 05:10 PM
njmaxseltd's Avatar
Cold oil usually produces higher pressure because it's thicker. The diesel type of noise could be coming from your combustion being very rich. Try a complete intake cleaning process, I'm talking taking the runners off and all. There are a few products that claim to be able to clean your intake without dissasembly, I think 3M or Champion makes a system. Sea Foam might be another one. Another thing to consider is your ECTS. It's a cheap sensor and might be off enough be effect your cold A/F ratio. You might be running to rich when your engine is cold.
Old Dec 3, 2003 | 05:12 PM
mzmtg's Avatar
ECTS is new...
I may tackle the intake cleaning one of these weekends coming up.
Mahmuth
Aug 16, 2024 08:23 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
