Desperate - Misfiring - Help
Old Dec 6, 2003 | 06:42 PM
gabex's Avatar
Ok, 0603 - Cylinder 6 misfire. Car is running very rough.
Changed plugs, OK.
Checked coil backs, OK.
Checked fuel injectors-#6 happened to be bad.
Had a problem w/ excessive gas burning out the exhaust. Fumes, white smoke, etc. BAD gas mileage. High pitch whining like a smoke detector sometimes at idle.
Changed bad fuel injector. Thought that everything was gravy. Drove about 10 miles it was great. 4 hours later, started car.. had trouble. Symptons return........
Old Dec 6, 2003 | 06:55 PM
R5a7B's Avatar
same thing happened to me, it was the wire connecting the cylinder to the ecu. a mouse chewed through my wire and resulted in cylinder 6 misfiring. until i get a new ecu tho, i am running on 4 cylinders. hopefully that wont be the case with you.
Old Dec 7, 2003 | 06:32 AM
gabex's Avatar
Forgot to mention, to test the injector from #6, assuming that was the one that was bad since it was a misfire in cylinder 6, we switched it with the injector from #2. This changed my misfire to multiple cylinder misfire. Then I got a multimeter and actually tested them.
Old Dec 7, 2003 | 03:49 PM
gabex's Avatar
Anybody???
Old Dec 8, 2003 | 09:08 AM
gabex's Avatar
Oh yea, another thing to mention.. I used PFR5G-11 plugs, and replaced the injector w/ a Bosch from thepartsbin.com
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
