Guess my problem, see if your right
Old Dec 8, 2003 | 06:17 PM
waveridr85's Avatar
Ok, accidnetly reset the ecu and lost the cel. Gotta wait for it to come back now. Lets see who can guess the problem before the ecu tells me.
Clues:
Idle seems to be low, especially when in gears (auto)
Problem started the day of the blizzard
Idle is low when my heat is on
95 se w/ 70k
Its pretty cold out
Lets see who wins, even though i dont have anything to offer, well maybe a set of orange bumper lights if you pay shipping, or hyper white/blue fog bulbs if you pay shipping
Old Dec 8, 2003 | 06:24 PM
nismos14's Avatar
§è~® f®ÈÄk
bet its an evap or iacv code
Old Dec 8, 2003 | 06:45 PM
rik3k's Avatar
Replace Engine code probably.
Old Dec 8, 2003 | 07:09 PM
maximagtr420's Avatar
High Beam Fluid???
Old Dec 8, 2003 | 07:10 PM
bye the way if you try to check codes it will give them to you even if light is off, try it. works for me.
Old Dec 8, 2003 | 07:13 PM
Stephen Max's Avatar
Originally Posted by maximagtr420
High Beam Fluid???
I was going to guess low blinker fluid, but why would cold weather affect that? I dunno.
Old Dec 8, 2003 | 07:15 PM
maybe he has no line defroster on the light fluid reservoir, that will get ya every time........
Old Dec 8, 2003 | 07:41 PM
waveridr85's Avatar
yea maybe my automatic transmision fell out, i checked the blinker fluid but it seems to be normal, maybe its my clutch? i cant seem to find it, maybe its my drive shaft or brake bands?
Old Dec 8, 2003 | 07:45 PM
climb under your car, follow the flux capacitor to your muffler bearing, give it a good shake, sometimes the darn spitzer valve in there goes bad and it will reverse the flow of your exhaust thus thrusting air back through the bearing.
simple solution:
Chewbaka Theory.......
Old Dec 8, 2003 | 07:46 PM
my99maxisnice's Avatar
Congratulations, you made me laugh.
Old Dec 8, 2003 | 07:54 PM
waveridr85's Avatar
i found it, looks like the vtec is set too early
Old Dec 8, 2003 | 07:56 PM
HAHAHAHA yea my buddys ranger pick up had that same problem...... but seriously, you should be able to just turn the screw like you normally would to check codes, and it will still blink them out to you if there is a problem.
Old Dec 8, 2003 | 08:28 PM
ivelweyz
IACV, some coolant related ****, thermostat, tranny fluid, check the TCU for codes...
Old Dec 9, 2003 | 07:31 AM
waveridr85's Avatar
i will check the cel it came back today, had a really hard time starting the car, almost as if the bettery had died, started like a carb car, had to feed it gas so it would rev, other wise no start, wierd i tell ya
Old Dec 9, 2003 | 09:01 AM
phatmax95's Avatar
Dude that happened to me the other day, I had to give it gas for it to stay on or else it would shut off after running for 1-2 secs.
Old Dec 9, 2003 | 10:15 AM
waveridr85's Avatar
yup yup, got the codes... unfortunatly no one was right no no freebies lol,
and the answer is : Rear Heated O2 sensor
looks liek the thick snow i went over once or twice focked my sensor up, maybe its jsut loose or something, but i bet its fried form all the water getting in it or being knocked around too much
Old Dec 9, 2003 | 10:21 AM
That may be the code you got, but that is not what is causing your idle speed to be low. The rear heated O2 sensor is not used by the ecu in closed loop operation. So somebody may still have provided the right answer. Probably needs a TB and IACV cleaning.
Old Dec 9, 2003 | 10:42 AM
waveridr85's Avatar
i have cleaned the throttl body before so i cant see that being the problem, wouldnt a problem like that slowly come,i mean one day i would start it up when it was cold and it would idle at a normal 1300 until it warmed up, now it was just idling at 400 - 500 rpms within a day, i doubt it can be a cleaning but i may be wrong, anyone got a write up on how to clean the iacv?
matts95max
Apr 23, 2025 10:44 AM
Mar 12, 2020 12:06 AM
ajahearn
Sep 19, 2015 03:03 PM
pjgreek
Sep 9, 2015 09:30 PM
slowlifer
Sep 8, 2015 05:53 AM
