Can I use 97-01 SE steering wheel on a 96?
Old Dec 8, 2003 | 07:18 PM
190hpKiLLA's Avatar
Granny Driven
I dont really like the cheap beige skinny looking steering wheel on my 96. Can I swap out for the nice black thick SE steering wheel of a 97+.
Old Dec 8, 2003 | 07:24 PM
vsamoylov
no, connectors for cruise control is different. I really don't like the fat ones cause they are not comfterable.
Old Dec 8, 2003 | 08:03 PM
190hpKiLLA's Avatar
Granny Driven
ok lets say i will sacrafice the cruise control. Can i do it then?
Old Dec 8, 2003 | 08:06 PM
PoePoe2797's Avatar
Not sure about the whole cruise control thingy but you'd have to get the airbag also, which is $$$
Old Dec 8, 2003 | 08:20 PM
meccanoble's Avatar
Sports Button FTW
i believe 96shogunmax has a 96 maxima with a 97+ steering wheel. He has a GLE and never mentioned anything about cruise control not missing. Its just the airbag which creates a problem. I think you have to get a 97+ airbag to accompany the steering wheel...96's wont work from what i remember....
Old Dec 8, 2003 | 10:02 PM
vsamoylov
yes, the airbag is different, the wheel, and the connector to the cruise control. I did it with my moms car. Her bag was deployed and i had a 1997 i30 sterring wheel with airbag and put that it. everything worked except the cruise.
Old Dec 8, 2003 | 10:56 PM
190hpKiLLA's Avatar
Granny Driven
where did u get the key to the air bag? i remember that u need a special key to take it out.
Old Dec 9, 2003 | 05:26 AM
nupe500's Avatar
Jedi Knight
You ARE correct the connectors for the cruise as WELL as the airbag are different, but it can be done by simply removing the ENTIRE wiring harness from the interior of a 97, which involves gutting the entire car...then you have to take apart the little module behind the steering wheel...it has airbag stuff on it...and replace it with the 97, to get everthing to work properly. I got everything to work for me for a day and a half but think that I've blown a fuse somewhere, so no worky...but the steering wheel fits and looks and feels much better than the stupid 95 gxe wheel I had in there...oh...airbag for sale too...hit me up!
Old Dec 9, 2003 | 11:43 AM
vsamoylov
i got my tools from a auto store like kragen, autozone,pepboys. it is a tool kit designed for airbags. $15 bucks
Old Dec 9, 2003 | 12:59 PM
Nismo3112's Avatar
Custom User Title
Now is the COMPLETE wiring for the cruise and airbag different? or just the connectors? If its just the connectors u can cut and sodier ur old connectors to the new bags and cruis right?
Old Dec 9, 2003 | 02:08 PM
190hpKiLLA's Avatar
Granny Driven
Hold on a sec...
Only the cruise control connector is different?
or
Both the AIRBAG & Cruise is different.
Vecause If i have to gut the whole car for the airbag to work I wont do it. But ifs its the cruise control then i dont care if it works or not.?? Please respond...
Old Dec 9, 2003 | 03:16 PM
bruteMax's Avatar
wouldn't a wheel cover do the trick? Takes care of the "skinny" quality at least.
These look good:
www.wheelskins.com
here's a half-shot of my $9 wheel cover. Feels good and the side trim matches my seats so
http://207.236.3.100/IMG_0017.JPG
Bill.
Old Dec 9, 2003 | 03:28 PM
NookieMax's Avatar
PM 96shogunmax hes got a sick '96 that has the all the looks of a '99
Old Dec 9, 2003 | 03:40 PM
vsamoylov
probably the connectors but the color of the wires might be different also. you should ask somebidy that has a 99 max what colors the wires are to see if they are the same as yours and use a voltmeter to check if they give a different reading also. research
Old Dec 9, 2003 | 05:19 PM
Nismo3112's Avatar
Custom User Title
I'll look up the wire coding in my haynes manual and report back here
Old Dec 9, 2003 | 06:29 PM
Nismo3112's Avatar
Custom User Title
Ok for the cruise, the connectors are different but both only have 3 wires:
95-96 models:
______________
|_1_|_2_|_3_|_X_|
97-99 models:
___________________
|_1_|_X_|_3_|_X_|_2_|
so my guess is just the connectors are different u just need to re-arrange the wires.!
Old Dec 10, 2003 | 07:51 AM
190hpKiLLA's Avatar
Granny Driven
95-96 models:
______________
|_1_|_2_|_3_|_X_|
97-99 models:
___________________
What about AIRBAG wires?? are they plug and play. I need to know this because Im getting a steering wheel with airbag of a 00 SE.
Old Dec 10, 2003 | 08:03 AM
nupe500's Avatar
Jedi Knight
Hate to burst your bubble, but the airbag plugs are definatly different...it maybe because my 95 was a GXE while all the parts came from my crashed 97 SE...could be jus the trim difference, but I know for a fact that they are different.
Old Dec 10, 2003 | 01:49 PM
Nismo3112's Avatar
Custom User Title
So how did you go about installing it? Or did you return it and get the right one for your model year.?
Old Dec 11, 2003 | 09:09 AM
nupe500's Avatar
Jedi Knight
Well...I ended up completely rewiring my 95 to be a 97...so that solved my problems...I mean...I gutted both cars...and basically reconstructed the 95 to be a 97..only thing that is original 95 is the steering column, the doors, and the chassis
Old Dec 13, 2003 | 10:57 AM
190hpKiLLA's Avatar
Granny Driven
I just spoke to 96showgun max and he said that it was direct swap./ So i dont know what to do now. I was supposed to get a 2K steering wheel with airbag.
Old Dec 13, 2003 | 11:16 AM
96shogunmax's Avatar
First off...
97-99 SE steering wheel and get the 97-99 cruise control switch.
THESE TWO ARE A DIRECT SWAP. Connectors are plug and play. You have to drill a hole out on the steering wheel alittle bigger to get it to fit over the clockspring right. THERE IS NO NEED FOR A COMPLETE WIRING HARNESS CHANGE.
EDIT : total cost for me was $300 bucks switch and airbag and wheel from another org member. Sometimes you just have to be a pioneer.
Old Dec 13, 2003 | 11:00 PM
ManualMaxima's Avatar
5th Gen till she dies!
you know f- the airbag!!!! hahaha
Old Dec 13, 2003 | 11:02 PM
vsamoylov
a little weight reduction. and take off the passenger one too and take the cover of it and put that back into the dahsboard without the bag. lol
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
