idle problem ??? anythoughts
Old Dec 9, 2003 | 09:46 PM
maxi fo life's Avatar
Well after cleaning my throttle body on my 97se max, the car has been running alot smoother and feels alot quicker, but the idle moves up and down from like 650 to 750 rpms. I know for a fact the idle is'nt suppose to move up and down and it's really ****ing me off. Also when I start up the car in the morning the idle shoots up all the way to 2000 rpms is this normal????Guys if you can help me out I would really appreciate ,because I know you guys know evrything about the max.
Old Dec 9, 2003 | 09:50 PM
my99maxisnice's Avatar
I know you after you clean your throttle body, you're supposed to go back and manually set your idle, write up on here somewhere.
Old Dec 10, 2003 | 02:04 PM
Kevlo911's Avatar
Kevlo for President
my car jumps to 1600 and stay there for 1 minute and drops to 1k and goes to 700 when its warm.
clean ur IACV, how to should be in 4th gen how to's under engine or hte maintanence links; how to link in my sig
Old Dec 10, 2003 | 03:00 PM
thanks for the info guys I really apreciate it. I'll go try what you guys said.
Old Dec 10, 2003 | 03:04 PM
nick's Avatar
re
there should be no need for throttle adjustmeants after cleaning the TB
Old Dec 10, 2003 | 03:13 PM
BlueBOB's Avatar
not necessarily true...
With a dirty tb, the air flow is restricted... and now that you have a clean one, the butterfly valve can move easier and the air can flow better... it's a slight side affect, but it shouldn't be THAT bad... just try readjusting and cleaning you IACV... that'll help a lot too... that thing was black when I pulled mine out.
hope that helps...
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
