Blinker/Corner Lights Rewire.
Old Dec 11, 2003 | 08:17 AM
PearlWhtMaX2000's Avatar
i tried posting this in the 5th gen section, but no one really knew what i was talking bout. i have a 2k max, and i know that with the 4th gen max you can rrewire the front blinbkers to make them bright all the time, can i do thye same w/my 5th Gen?? any help would be great. Thanx
Old Dec 11, 2003 | 08:23 AM
97blackSE's Avatar
i will do it for ya at the meet if you like...
you just have to put your bulb in backwards, essentially
Old Dec 11, 2003 | 08:55 AM
really?? what do u mean, so u dont have to mess w/the wires??
Old Dec 11, 2003 | 08:56 AM
97blackSE's Avatar
nope...1157 are a dual filament bulb...you put the bulb in backwards and it lights the brighter filament..Grind off the upper **** on your 1157 bubls, and put that motha trucka in backwards
Old Dec 11, 2003 | 08:57 AM
i get the grinding part but what do u mean put it in backwards??
Old Dec 11, 2003 | 09:05 AM
rdaneel's Avatar
The bulb has two nubs, a higher (closer to glass) and a lower. The stock way to put it in is with the lower nub in the lower part of the socket (you'll see the two slots are different depths in the socket). To make them brighter, use nail clippers or something to clip off the upper nub and cover that part with a very thin and narrow piece of electrical tape. Then insert the bulb so what used to be the lower nub goes into the higher (or shallower) slot. Viola! brighter corners...
Old Dec 11, 2003 | 09:07 AM
97blackSE's Avatar
thats a good way to word
it rdaneel...
Old Dec 11, 2003 | 09:12 AM
rdaneel's Avatar
Oh, forgot to say, the 4th Gen How To sticky has a link to the VWPower write up that helped me do this mod: http://www.vqpower.com/v2/modules.ph...howpage&pid=50
Now all I have to do is get rid of this "I need to read the FAQ and IMPORTANT threads before posting a question" tag on my name!
Old Dec 11, 2003 | 09:16 AM
ok sounds easy, thanx alot guys
Old Dec 15, 2003 | 12:57 AM
boyzindahood978's Avatar
Im having a hell of a time trying to pull the corner lights out. I unscrewed the one screw next to the headlight, tugged at the corner light but it won't budge. I don't want to crack it by pulling any harder. Should it be this hard?
Old Dec 15, 2003 | 01:30 AM
PeTeRtheEaTeR's Avatar
first time for me was hard. Try spraying WD-40 where the nub is and get a flathead screwdriver and pry it out. It should help. First time i did it, it came out violently but perfectly.
Old Dec 15, 2003 | 06:53 AM
BOZOnPJs's Avatar
if you look between the headlamp and the corner lamp down by the bumper and not where you removed the top phillips you will see a small ball and socket joint.. spray that with WD40 if you have any handy.. if you don't, aim good and spit a louie in there... hahaha j/k.. with a flat head screwdriver pry it a little bit and then pull.. it should come out no problems.
Old Dec 15, 2003 | 06:57 AM
mzmtg's Avatar
Minister of Silly Walks
Um....
The corner light on the 5th gen IS the turn signal. It flashes. You dont want to re-wire it or turn the bulb around.
Old Dec 19, 2003 | 07:17 PM
Originally Posted by mzmtg
Um....
why not?? u saying it wont blink? if o do
Old Dec 23, 2003 | 12:50 PM
?? no respopnse?
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
