Help. My parking brake light is always on
Old Dec 11, 2003 | 10:06 PM
budha56's Avatar
My parking brake light is always on when the car is on. It doesn't feel like the brake is pulling at all. Anyone have any suggestions? Thanks!
Old Dec 11, 2003 | 11:23 PM
Ladzio's Avatar
hmmmm, gotta ask - is you e-brake all the way down?
I believe there is also a switch beneith the e-brake, probably it got jammed??
Old Dec 11, 2003 | 11:51 PM
budha56's Avatar
Haha. Yes, my ebrake is all the way down and my TV is plugged in. There's a switch beneath the ebrake? Hmmm, I'll check that out. Anyone have any better instructions on how to find it, or is it pretty easy to find? Thanks.
Old Dec 12, 2003 | 02:22 AM
Nismo's Avatar
Check your brake fluid level in the resovoir
Old Dec 12, 2003 | 04:37 AM
njmaxseltd's Avatar
Brake light always on = Low brake fluid.
Old Dec 12, 2003 | 04:47 AM
Ladzio's Avatar
cool, I never knew about that so will keep in mind
Old Dec 12, 2003 | 05:51 PM
budha56's Avatar
Thanks! That's good to know. Can I just use any brake fluid?
Old Dec 12, 2003 | 07:55 PM
Nismo's Avatar
Dot 3 fluid.
BTW- Low fluid level and no sign of a leak indicates that your brake pads are worn out, better check your pads too
Old Dec 12, 2003 | 10:31 PM
budha56's Avatar
Wow I'm learning a lot here. How can I tell if my brake pads are worn? I didn't see anything about this in the how to/FAQ section.
Old Dec 13, 2003 | 05:39 AM
twiggy144's Avatar
Measure the thickness of the pads on all wheels, New pads are 10mm thick. At 2mm pads are 99% worn. It is a good practice to replace pads at 4mm or less though.
Old Dec 13, 2003 | 05:59 PM
budha56's Avatar
Yep. The brake fluid took care of the light right away. I'll look at my brake pads tomorrow. Thanks.
Old Dec 13, 2003 | 10:27 PM
Ladzio's Avatar
You could fit a small mirror between the spokes of your rims or to be 100% sure you would have to take the wheel off.
Old Dec 13, 2003 | 10:47 PM
vsamoylov
yeah, if break fluid is low, light will stay on. that happend to me on 2 different cars when i was bleading my brakes. but i doubt that worn brake pads will signal a light. also if rear brake pads wear too fast, you e brake wire most be too tight. that happend to me also.
Old Dec 14, 2003 | 12:05 AM
Jepht20's Avatar
Custom User Title...
oddly enough, i had that problem a few months back and my fluid and pads were fine. it kept going on and off and then stopped for good. not sure what that meant cuz i brought it somewhere and they said everything looked fine...
cars (when they're not working right) drive me nuts.
Old Dec 14, 2003 | 02:03 AM
Nismo's Avatar
Worn pads = more distance the piston has to travel = more fluid taken from the resovoir to compensate = low fluid = brake light
Old Dec 14, 2003 | 10:31 AM
vsamoylov
yeah, i hate when cars get a problem. for example, i was driving my 96 max one day and out of nowhere my check engine light comes on. i was like ok, now what. first thing that came to my mind was speed sensor because of my new wheels because the computer finally adjusted to them so the light came on. But when I get home, i pull my scanner out, and plug it i. it says that evaporative gases from the canister were throwing a code. i deleted the code and never came back.
tsi6001
Oct 3, 2022 10:23 PM
Sport
Jul 3, 2017 05:40 PM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
