Misfiring? NO code
Old Dec 12, 2003 | 05:49 AM
mzmtg's Avatar
Minister of Silly Walks
Misfiring? NO code
My car has started misfiring intermittently. When stopped, it makes the whole car jerk. When driving, there are noticeable jerks in the power delivery.
The weirdest thing is that I get no CEL and there are no stored codes.
Tonight, I'm going to check the following sensors:
MAF
Cam pos
Crank pos
Crank phase
Coils
Injectors
Is there anything else I should look at?
Old Dec 12, 2003 | 05:58 AM
deezo's Avatar
Bad plugs?????
Faulty injectors????
Hopefully its not the ECU. Check to make sure its connector is bolted in good.
Old Dec 12, 2003 | 06:08 AM
mzmtg's Avatar
When I changed the plugs about 2 months ago, there was some oil in the #3 plug well. Could it be related? I tried to clean it out as best I could, but there may have been enough seepage since then to interfere...
Old Dec 12, 2003 | 06:27 AM
deezo's Avatar
Possibly. You may have to break down and replace the gasket. That oil could be fouling the spark plug.
Old Dec 12, 2003 | 06:45 AM
Shift's Avatar
I had no code also and had the same isssues as you. I made it come on. Over reved in 2nd. The serivce engine light flashed on and off about 4-6 times. then stayed off. It was enought to lock the computer to run a check. I found out I have a misfire in #5.
Now,,, gotta see if its a injector, coil or plug.
Old Dec 12, 2003 | 07:37 AM
gabex's Avatar
Jesus H Christ...
So many people misfiring.. Me, Shift, mzmtg, JeEve, and more! What is happening to our cars?
Old Dec 12, 2003 | 08:01 AM
mzmtg's Avatar
Originally Posted by gabex
Jesus H Christ...
I believe the proper term is:
"jumping jesus on a pogo stick"
Old Dec 12, 2003 | 08:54 AM
MAXimumHP's Avatar
Does seem to be a problem lately. It's surprising multiple occurrences of a misfire doesn't throw a CEL easier.
Old Dec 12, 2003 | 09:18 AM
gabex's Avatar
Does anyone know the part number for the coil packs? I can't seem to find them online anywhere.
Old Dec 12, 2003 | 09:21 AM
Jepht20's Avatar
Custom User Title...
Jesus H Christ...
add me to the list. time for maintenance.
Old Dec 12, 2003 | 09:30 AM
s0ber's Avatar
Same here, if only I could get the car to start first, then i'll fix that problem.....
Old Dec 12, 2003 | 09:46 AM
big_al's Avatar
Ya, when my injector went bad, I had to really push the car to get a code. But once you get a code its alot easier to pin point the problem.
Old Dec 13, 2003 | 02:46 PM
gabex's Avatar
Did anyone find out what their problem was yet?
Here's my situation:
Took my car to a shop to have them install my 2k2 muffler.
Next day, car is running rough. Check ECU for stored codes.
0603-Cylinder #6 misfire. Replace all spark plugs (NGK PFR5G-11).
Checked for sparks. Still misfiring.
Decided fuel injectors must be bad.
Swapped #6 fuel injector with #2. Reset ECU, Started car.
Problem got worse, running even rougher. 0701-Multiple cylinder misfire.
Gas leaking out weld in new muffler.
Decided that injector #2 (previously #6) must've been bad.
Checked it with a multimeter, Replaced injector #2 and O-rings
on injectors #2 and #6. Reset ECU, Started car. All GOOD!
Let the gas burn that was in the exhaust, drove around 10 miles.
Everything seemed fine, 0701 returns. Still misfiring.
Pulled injector #4, it was busted. Bad o-rings, cracked.
Replaced injector #4 and o-rings, Reset ECU, Started car.
Checked ECU 0607-Cylinder #2 misfire.
Figured it could not be the new fuel injector. Swapped
coil pack #2 with #6. Reset ECU, checked codes.
Still 0607-Cylinder #2 misfire.
I don't have my multimeter. Could the fuel injector have gone
bad already? Or what other problems could there be causing this
misfire??!
Possibly unrelated: Under 1k RPM, REALLY high pitch noise. Radio
and lights were off. Dunno what it is??!
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
zmcneely13
Sep 26, 2015 02:26 PM
