removing seats
Old Dec 13, 2003 | 05:38 AM
mungrin's Avatar
removing seats HELP!!
Anyone have a link or a guide that shows how to remove all the seats?Im finally going to change my seats today but can get them out.I thought it would be easy but i was wrong.
Old Dec 13, 2003 | 06:44 AM
bravehart's Avatar
It is easy. Front seats have four bolts each, two in the front two in the rear. Rear seat lower cushion has two clips, each clip is about a foot from the door. Pull on clip then lift up on seat. Upper rear seat has four bolts one in each corner. Haynes breaks it down fairly well.
Old Dec 13, 2003 | 06:55 AM
sean carter's Avatar
If I change my seats to leather seats, there will be no way to adjust it right? Can I add something to it to give it power?
Old Dec 13, 2003 | 07:27 AM
bravehart's Avatar
Should be easy. The controls for the seats are on the seats themselves so it should be a matter of supplying a constant supply of 12 volts. I just checked the wiring on my power seats, there are four wires. Two for the seat belt indicator, two for the power seats.
Old Dec 13, 2003 | 10:14 AM
mungrin's Avatar
got them all out except the top back one cant find the 2 top bolts
Old Dec 13, 2003 | 10:27 AM
Jepht20's Avatar
Custom User Title...
top ones have the two bolts at the bottum, two bolts behind the armrest. and have 4 or so clips at the top so you basically just lift it up and out once the bottum bolts are off....hope that helps and goodluck.
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
jaydot901
Sep 29, 2015 01:18 PM
