Filter-only intake issues
Old Dec 15, 2003 | 05:00 PM
mrnock's Avatar
hey, i have a k&n filter on my max (95, 63k miles, otherwise stock) .. i have some issues with the performance side of it.
when i stomp on the gas from a start, i barely get any tire spin. i know the torque loss is noticeable, but damn, is it that bad? plus i have a system.
when under hard acceleration, i notice a drop-off in power just below 4k RPM. i can correct this only by going WOT.
when going up a slight incline and my trans is in 3rd or 4th gear, power is nearly not even present. once i noticed that my RPM was staying the same while the MPH was decreasing
can anyone state what the reason might be?
Old Dec 15, 2003 | 05:49 PM
MaximaEvolution's Avatar
Your knock sensor might be going bad. Is the CEL lit up?
Old Dec 15, 2003 | 05:51 PM
nismos14's Avatar
§è~® f®ÈÄk
the CEL will not light up most of the time with a knock sensor problem
Old Dec 15, 2003 | 09:54 PM
mrnock's Avatar
CEL = not lit. i have been getting less than avg gas milage. should i check the ECU anyhow?
Old Dec 16, 2003 | 02:29 AM
Max Noob's Avatar
sounds liek a bad knock.. check it..
Old Dec 16, 2003 | 06:19 AM
eric96se's Avatar
Like the others have said check your codes and see if you have a K/S issue. I actually disconnected mine and drove around and my car felt the same. I was getting 250 mi to the tankful when I was used to getting 340+ per tankful. I ordered my K/S on ebay and had it swapped out in an hour using the www.skippynet.com method. Since the day I bought my car I don't think I was ever able to break the tires loose from a dead stop. Now I can and the car is more fun to drive.....Good luck
Old Dec 19, 2003 | 05:45 PM
mrnock's Avatar
just checked the ECU, got 0505.
i dont want to get a bloody hand and 90 dollars poorer for a petty knock sensor that might or might not be bad. are there other places i should check?
power is incredibly low under 3,000 rpm. once 3k hits power comes back quickly.
Old Dec 21, 2003 | 11:48 AM
mrnock's Avatar
bump,.......
Old Dec 21, 2003 | 04:51 PM
nismos14's Avatar
§è~® f®ÈÄk
coil packs, spark plugs, do some regular maintanence, maybe that will help
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
