Shifting problem with RPMs......HELP !!!!
Old Dec 15, 2003 | 06:20 PM
5speeddemon's Avatar
Ok, when I race my car I have a problem with the rpms staying above 4 gran if I shift that high. Just say if I shift from 2nd to 3rd and so on above 4 gran it just stays there until I let off the gas!!! What causes this and how can I fix this problem. PLEASE HELP!!!!!
Old Dec 15, 2003 | 07:29 PM
nismos14's Avatar
§è~® f®ÈÄk
what do u want to happen? have the rpms drop to 1000? thats not going to happen, especially if ur racing.
Old Dec 15, 2003 | 09:58 PM
I know that but, theres got to be something that can be done to keep it from just rebbing up and no going any where. What I'm tring to say is does anyone else have this problem. It sucks to be raceing and you can't run out your gears and then shift to the next gear. Why have a stick if you can't do that, I have to shift before 3 grand that sucks. I guess what I really want to know or need my rpms to do is to drop faster so that i cant shift to the next gear. I need help there has to be something!!!!! So of you guys tell me how you shift while you race maybe that will hepl me out.
Old Dec 15, 2003 | 10:09 PM
araffio's Avatar
Your wording is very confusing and your question is unclear. If you can't run the car to redline, then something is wrong. There's no reason you should have to shift at 3k rpms, ever.
Run the car to 6k, shift fast, then run it some more. Simple as that.
From reading your post about 5 times, it seems as though your clutch is shot and is slipping at higher rpm's. Get yourself a new clutch and call it a day.
-Tony
Old Dec 16, 2003 | 07:08 AM
nismos14's Avatar
§è~® f®ÈÄk
-Tony
Tony's right i agree. def seems like a clutch issue, as if its slipping like hell.
Old Dec 16, 2003 | 07:14 AM
nismos14's Avatar
§è~® f®ÈÄk
also if ur not letting off the gas, why would the rpm's drop? they're not supposed to if ur not letting off the gas :
Old Dec 16, 2003 | 06:34 PM
bananamax's Avatar
It sounds to me that he is not letting off the gas, or perhaps the cable is sticking. Either way, some communication skills are needed.....
Mar 12, 2020 12:06 AM
ajahearn
Sep 19, 2015 03:03 PM
2kmaximel
Sep 16, 2015 03:19 PM
