yellow fogs
Old Dec 16, 2003 | 12:47 PM
blkhawk500's Avatar
yellow fogs
first of all, sorry if this is was already disscussed ...I want to get some yellow H3 fog light bulbs. Which is better PIAA ion crystal, NARVA candlepower, or someother brand?
thankx in advance
Old Dec 16, 2003 | 01:12 PM
endus's Avatar
An atavistic endeavor...
The PIAA's are ricey, not that yellow, and insanely overpriced. The Narvas are the only 85W yellow foglight bulbs that have lasted anything close to a reasonable amount of time (~1 year) in the stock housings for me. I recommend them, but if you get them and like them make sure you order a couple spares before they burn out...very annoying when one goes.
Old Dec 16, 2003 | 04:39 PM
blkhawk500's Avatar
how long will the PIAA last?
Old Dec 16, 2003 | 04:43 PM
MrDicks95SE's Avatar
Offset Is Everything.
yellow film the lense.
Old Dec 16, 2003 | 04:47 PM
blkhawk500's Avatar
instructions?
Old Dec 16, 2003 | 04:53 PM
Iron Scimitar's Avatar
Tha Snatcher
Mine are okay, i installed mine spring of this year.
Old Dec 16, 2003 | 05:03 PM
for using film on the lense? well its just like redding out the corners (read the FAQ for that). im not sure but i think you do it to the outside of the lense not the inside. not sure about it but ya hafta go look into that. just go to your local hobby store and pick up translucent yellow film. take out fog and bulb, wash lense with soapy water, let soapy water drip down, then apply film onto sopay water, use something flat like credit card and push out all the airbubbles and water, then use heat gun to dry it and stick it. i actually wanted to do it but cant due to some circumstances. 3M has a protective film you can use ontop of it to protect it from scratches or somthing like that.
anyone else care to explain better? im not 100% sure anyways.
Old Dec 16, 2003 | 05:15 PM
blkhawk500's Avatar
sounds good to me..thankx
Old Dec 17, 2003 | 03:22 AM
Max Noob's Avatar
narva rally gold H3 from SUVLIGHTS.COM 40 bucks shipped i think.. check my sig for a picture..endus referred those to me a while ago.. they are awesome.. i was considering film/painting too but did not want the lense to look yellow in the day time.. try these first..they work great.
Old Dec 17, 2003 | 06:38 AM
blkhawk500's Avatar
Anyone ever tried Hella yellow star?
Max Noon: very NICE!!!!...how long have they lasted so far?
Old Dec 17, 2003 | 06:42 AM
blkhawk500's Avatar
I noticed on suvlights.com that the rally golds are 85 watts. Did you have to upgrade anything before installing?
Old Dec 17, 2003 | 06:50 AM
endus's Avatar
The Hella Yellow stars were short lived, but produced BY FAR the best yellow light of any bulbs I ahve tried when they were still made in Germany. They are now manufactured in Korea and the quality is way down. I ordered like 6 of them after having used the German ones for a long time, put a set in and one burned out in **less than a week**. The color is also not as good as it used to be. In short, they were good, but they are now garbage.
As far as the PIAA's longevity, I have no idea. I had them in for a few weeks and took them out when I got the Narvas...I jsut wasn't satisfied with them at all.
Old Dec 17, 2003 | 07:04 AM
MaxedOutOfCash's Avatar
Pizda Boy
NARVA / PHILIPS - Rally Gold 85W $18/Each
at suvlights.com
you'll be happy with them.
Old Dec 17, 2003 | 07:16 AM
blkhawk500's Avatar
at suvlights.com
Do they last longer than the Candle powers and can i just do a direct replacement w/o upgrading anything?
Old Dec 17, 2003 | 05:59 PM
Max Noob's Avatar
no need for replaceing anything in the fog.. the wiring has held up well..its not as cheese as the headlight wire harness. no idea if the last longer than canlde power.. im on my first set of narvas.. i will get another set when.if these ever blow out. ive had them for about 6 months with no problems.
some have reported cracked lenses from the 85 bulbs making the glass too hot.. when they hit a puddle.. the sudden cooling makes the glass crack.. has not happened to me.. i drive with them on all the time.. never had a crack..somethig to think about.
i still recommened narva.
i tried the hella yellow star from korea.. they suck ballsss..no yellow.. they jsut look liek dirty halogen.i have a set for free if you want them.jsut pay me for shipping.
Old Dec 17, 2003 | 06:16 PM
MaxSpeedSE's Avatar
Couldn't you just buy transparent paint like you do for the tail lights, and actually paint the stock bulbs?
Old Dec 17, 2003 | 07:33 PM
no thatll screw up the bulb and burn it out. thats what i tried. it starts to smoke and stuff.
Old Dec 17, 2003 | 07:34 PM
no thatll screw up the bulb and burn it out. thats what i tried. it starts to smoke and stuff. not a good idea.
Old Dec 17, 2003 | 07:35 PM
woops too many
Old Dec 17, 2003 | 08:15 PM
sk24iam's Avatar
Is yellow better than like extreme white?
Old Dec 17, 2003 | 10:17 PM
ch13f's Avatar
In terms of visibility in the fog?... yes much better
Old Dec 17, 2003 | 10:54 PM
NISMOMAXMAN's Avatar
Is the yellow coloration your looking the LEXUS foglight yellow? Because that is a such a beautiful color that would look sweet on our cars. I too have been searching,...........nothing, Thinking about swapping fogs from a lexus, is it possible?
Old Dec 18, 2003 | 12:23 AM
Max Noob's Avatar
lexus uses a pod or convex projector lense that has a thin larye of yelow paint or film on it. that pod/lense goes around or in front of the a normal white fog bulb.. i guess u could try and make it fit, but youd have to be pretty creative. i looked into the project a while ago, but gave up. lexus owners make their fogs white or super white by sanding the paint or film off the projector lense. then puttig back on. so i couldnt get a set of lenses from them. i asked around the lexus forums. u try.
if u paint the bulbs, the pait will burn off in like 15 secs..pointless to try..
the first gen TL's and 2nd gen integ had yellow fogs. i dont know if those use a pod or film or if the bulb is yellow.. try checking that out.
wow that was long.
Old Dec 20, 2003 | 08:51 AM
sk24iam's Avatar
What color headlights look good with the PIAA ion crystal fogs?
Old Dec 20, 2003 | 09:17 AM
JeremyMarkham's Avatar
So these are H3 bulbs? Mine are yellow and I want white...suggestions on a good brand that puts out a nice white color?
Old Dec 20, 2003 | 04:53 PM
sk24iam's Avatar
PIAA xtreme
Old Dec 20, 2003 | 07:00 PM
SXN's Avatar
SXN
not to *****, but are yellow fog lights better for actual fog, or do you guys just like the look?
Old Dec 20, 2003 | 07:41 PM
I like the look. I dont need fog lights here in Los Angeles. PIAA extremes ey? How how would a set run me?
Old Dec 20, 2003 | 07:49 PM
blkhawk500's Avatar
It makes you car more visible in the fog and I think they make a nice contrast with you headlights, especially if you have HIDs.
Old Dec 20, 2003 | 08:02 PM
SXN's Avatar
SXN
i like them on certain cars (hate to use a played out example, but ae86, especially panda paint, or 240...more square/older and drift cars) but never loved them on the maxima. I remember a 3rd gen with m3 projectors and yellow fogs...looked so awesome. with white corners, and bright headlights, i think VERY yellow fog lights look good as contrast, but Max Noob's car with all that orange isnt my thing (sorry Max Noob, i just needed an example )
Old Dec 20, 2003 | 09:07 PM
Max Noob's Avatar
its cool man.. everyones got their own style.. i just happened to like the amber and not super whites. to me blueish headlights and superwhites are kinda ricey.. and superwhite fogs and headlight and corners never match up well and look out of place. plus ill never get pulled over for my headlights.... but to everoens own right?
Old Dec 21, 2003 | 02:06 AM
SXN's Avatar
SXN
i got a gxe so i lack fogs, but my entire front end is full of white bulbs (amber turns, but aside from that) very deep dark yellow fogs interest me
Old Dec 22, 2003 | 07:05 AM
endus's Avatar
I ditched my PIAA superwhites when one blew. They are ****ty bulbs anyway...they give off less light then conventional headlight bulbs. All the silverstars and that stuff are crap...they DO look good IMHO, but they do not perform as well. Right now I am running Sylvania Xtravisions and liking them much better than the PIAA's in terms of performance. People should check this out when it comes back online...dude is the king of automotive lighting...
http://lighting.mbz.org/faq/FAQ.html
I still have my orange corners too...never liked clear turn signals on Green Maxes...and a lot of the maxes around here with them are mad ricey anyway...don't want to be associated with that. So basically I am more or less semi-stock looking except for yellow fogs which are much better than white for actual fog.
Old Dec 22, 2003 | 07:36 AM
hotmax97's Avatar
ohohhhhhhhhhhhhhhhhhhhhhhhhhh
Old Dec 22, 2003 | 09:05 AM
speedemn's Avatar
Having your foglights go whiter renders them even more useless as actual "fog" lights... they would function just as a second set of headlights, in essence.
Old Dec 22, 2003 | 09:07 AM
speedemn's Avatar
Yellow light has a longer wavelength compared to white light and hence is better for fog visibility. So there is a functional advantage to it.
(or is it shorter wavelength... but you get the idea)
The lower you go on the colour spectrum (red being the very lowest, the better fog visibility it will have). You might ask, why not get that in your headlights then? Headlights however are different because you want them to be brigher and a shoter wavelength for lighting up the road better.
Old Dec 22, 2003 | 03:03 PM
SXN's Avatar
SXN
lol, my point exactly
thanks speedemn, makes a lot more sense that way
Fbana41
Aug 29, 2016 12:18 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
