air intake temperature sensor in a K&N cone?
Old Dec 16, 2003 | 12:48 PM
myke321's Avatar
I read this on this guys max website: "Since the 95 Maxima is ODB-II compliant, it has an air intake temperature sensor on the factory air box. I had to drill a small hole in the end of the K&N filter, and mount the sensor. It all worked perfectly."
I have a K&N air filter, and i just have that sensor out side of the filter. Should it be inside like motorvate.ca states?
Old Dec 16, 2003 | 01:04 PM
95GreekMaxSE's Avatar
same for my cone filter, you get a more accurate reading of tempurature as far as the intake is conserened rather than the engine bay but not much of a difference.
Old Dec 16, 2003 | 01:06 PM
myke321's Avatar
So you have yours outside the filter?
By the way this is the site i got the info from, pretty cool,
http://www.motorvate.ca/mvp.php/1101
Old Dec 16, 2003 | 01:12 PM
motorvate.ca is an excellent site, I have the sensor inside. Basically, where the fabircated MAF adapter meets the MAF sensor and resonator, I wedged the wire between these to pieces and let it hang in the cone. Afterwards I siliconed to insure no vaccum leaks esp. around where the wire is wedged.
Old Dec 16, 2003 | 01:17 PM
myke321's Avatar
would you drill a small hole at the top for the sensor? Any drawback by doing this?
Old Dec 16, 2003 | 01:21 PM
there are no drawbacks as long as everything is sealed. Rubber and silicone usually help insure things are sealed.
Old Dec 16, 2003 | 01:27 PM
myke321's Avatar
Thanks for you help man!!
Old Dec 16, 2003 | 04:15 PM
nleja's Avatar
If you want to avoid modifying anything, I'd recommend getting some soft steel muffler strapping, and just rigging up a bracket using the existing mounting points for the stock air box. Takes about 2 seconds and positions the sensor dead on in the middle of the cone. Sorry I don't have any pics, but the job's easy enough.
Hope that gives you another option.
-n
Smackasmith
Feb 1, 2016 12:40 AM
220k+ A32
Sep 11, 2015 02:18 AM
lux97Max
Sep 4, 2015 05:42 PM
