car vibrates when wheels spin
Old Dec 16, 2003 | 04:08 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
when ever my car peals out the car violently vibrates, as if the front of the car is bouncing up and down, because of my suspension mods. my friend said i need motor mounts. is this true? where can i get them and how much. he also said that some people use the stock motor mounts from a 5th gen. thanks.
Old Dec 16, 2003 | 04:13 PM
dss42's Avatar
it is called wheel hop all maximas have it. Motor mounts wont fix the problem.
Old Dec 16, 2003 | 04:15 PM
MaxedOutOfCash's Avatar
Pizda Boy
Actually yes they will, polyurethane engine mounts are what you need. Many people say they make wheelhop less noticeable and you get less vibration from the engine.
Old Dec 16, 2003 | 04:21 PM
dss42's Avatar
isnt wheel hop related to the non differential or differential trannys?
Friend of mine has polyurethane engine mounts and still has wheel hop might of improve alittle..
I need engine mounts badly my engine shakes like a ****
Old Dec 16, 2003 | 04:22 PM
SXN's Avatar
SXN
nearly all front wheel cars do that. If you do a lot of burn outs and stuff, use crappy tires, with less grip they dont hop. If you are more trying to launch for dragging (which you arent, you're just doing peel outs) new engine mounts would help.
Since you dont NEED the mounts...why bother
Old Dec 16, 2003 | 04:35 PM
JeEvE's Avatar
This happend to be before, the dash shacks very hard and its kind of like a hard banging? This is my first car so I wasnt sure if it was normal or not. Does this happen when the wheels dont spin and they are gripping?
Old Dec 16, 2003 | 04:38 PM
SXN's Avatar
SXN
wheel hop happens when the wheels spin and slide. When they grip...you move forward. The wheel hop is caused by the tires partly gripping during wheel spin, so they kinda catch at ever rotation, cause a bumping and jostling feeling.
Old Dec 16, 2003 | 04:46 PM
KWheelzSB's Avatar
Btw,
Repeated wheel hop WILL cause your tranny to self-destruct, eventually.
Proceed with caution.
Old Dec 16, 2003 | 04:47 PM
Vlasic's Avatar
i have never experienced any wheel hop in my friends '03 maxima, when ever we peel out in that, its smoothe and stable. i believe he has kumohs(sp?)
Old Dec 16, 2003 | 04:50 PM
SXN's Avatar
SXN
little bit more engine beef, a lot less struggling by the engine to make the tires spin
Old Dec 16, 2003 | 09:52 PM
ABK's Avatar
ABK
stiffer engine mounts and stiffer springs always fix that
Old Dec 16, 2003 | 10:10 PM
Vlasic's Avatar
where can i find some polyurethane mounts?
i have intrax sprins which i have heard have the worst ride quality, and tokico hps, which ive also heard kinda suck lol. whats the best spring strut combo?
Old Dec 16, 2003 | 10:16 PM
Pizda Boy
southwestautoworks has some, there should also be a link somewhere telling how to make your own.
Old Dec 16, 2003 | 11:45 PM
SXN's Avatar
SXN
AGX strusts are pretty good, but they can give noise issues. Iluminas are becoming more and more popular. Your choice in springs depends on what you are looking for'
http://www.geocities.com/hampst1/page1.html
Old Dec 16, 2003 | 11:50 PM
wrongway15's Avatar
that happens to my 98, but i think its cause my new front rubbers arent balanced properly
Old Dec 17, 2003 | 12:15 AM
007max's Avatar
hmmm, i've never experienced wheel hop with either the stock wheels & tires or the 17x7.5's with low pro's i have now...my suspension is stock.
Old Dec 17, 2003 | 07:48 AM
dss42's Avatar
do u have auto or 5 speed?
Old Dec 17, 2003 | 04:53 PM
SXN's Avatar
SXN
either way, its generally because the tires have one spot that is higher and un balanced than the rest of the rubber. While the tire spins, that one part catches and bounces the car. That means basically the tires are gripping too hard. The newer maximas with bigger engines have no wheel hop because they have a loooot more torque...eliminates any issues
Lakersallday24
Jun 16, 2019 01:35 AM
trasmadean
Feb 1, 2017 08:20 PM
JMag90
Aug 25, 2015 09:17 AM
sc10692
Aug 9, 2015 09:37 AM
RealityCheck
Aug 5, 2015 06:18 AM
