Check Engine: P0440 &P1448
Hi all,
my second post,
in a friend's 98 Maxima the Check Engine has come on for a while.
Checked it and here are the codes: P0440 and P1448
was erased once and came back after a few days
codes mean
EVAP Small Leak and such
there are a few Nissan TSB's on this issue but I can't find more details, any help?!
where I shoudl start?1
my second post,
codes mean
http://forums.maxima.org/showthread.php?t=265311
0705 - P0440
0705
Diagnostic Trouble Code 0705 points to a problem with the Evaporative Emission Control System.
This malfunction is detected when the EVAP control system has a leak or the EVAP control system does not operate properly. (EVAP = EVAPorative emissions.)
Possible causes include...
- incorrect fuel tank vacuum relief valve
- incorrect fuel filler cap
- fuel filler cap vent remains open or fails to close
- foreign matter caught in fuel filler cap
- a leak in the line between the intake manifold and the
EVAP Canister Vacuum Control Valve
- foreign matter caught in the EVAP CVCV
- leaks in the EVAP canister or fuel tank
- leaks in the EVAP purge line (pipe and rubber tube)
- EVAP purge line rubber tube bent
- blocked or bent rubber tube to EVAP control system pressure sensor
- loose or disconnected rubber tube
- EVAP CVCV and circuit
- EVAP Canister Purge Volume Control Solenoid Valve and circuit
- absolute pressure sensor
- tank fuel temperature sensor
- MAP/BARO switch solenoid valve and circuit
- blocked or bent rubber tube to MAP/BARO switch solenoid valve
- O-ring of EVAP CVCV is missing or damaged
- water separator
- EVAP canister saturated with water
- EVAP control system pressure sensor
- refueling EVAP vapor cut valve
- ORVR system leaks
This is a "jackpot" DTC. It points to so many things you don't know what to check. It is often combined with another DTC which is more specific and therefore more helpful.
P1448 - 0309
0705 - P0440
0705
- water separator
- ORVR system leaks
P1448 - 0309
Originally Posted by kevlo911
magiconthetire
Oct 26, 2015 09:03 PM
