code 0705 evap control unit
Old Dec 18, 2003 | 10:39 AM
maxxximum90's Avatar
what is the most common problem giving this code? Loose gas cap???
I know there is a huge list of things that could cause it, but what has everyone here had wrong??? I replaced the ks since i got the 0304 code a month ago, and i got 0705 with it. Anyone?
Thanks in advance
Old Dec 18, 2003 | 01:18 PM
Kevlo911's Avatar
Kevlo for President
0705
Diagnostic Trouble Code 0705 points to a problem with the Evaporative Emission Control System.
This malfunction is detected when the EVAP control system has a leak or the EVAP control system does not operate properly. (EVAP = EVAPorative emissions.)
Possible causes include...
- incorrect fuel tank vacuum relief valve
- incorrect fuel filler cap
- fuel filler cap vent remains open or fails to close
- foreign matter caught in fuel filler cap
- a leak in the line between the intake manifold and the
EVAP Canister Vacuum Control Valve
- foreign matter caught in the EVAP CVCV
- leaks in the EVAP canister or fuel tank
- leaks in the EVAP purge line (pipe and rubber tube)
- EVAP purge line rubber tube bent
- blocked or bent rubber tube to EVAP control system pressure sensor
- loose or disconnected rubber tube
- EVAP CVCV and circuit
- EVAP Canister Purge Volume Control Solenoid Valve and circuit
- absolute pressure sensor
- tank fuel temperature sensor
- MAP/BARO switch solenoid valve and circuit
- blocked or bent rubber tube to MAP/BARO switch solenoid valve
- O-ring of EVAP CVCV is missing or damaged
- water separator
- EVAP canister saturated with water
- EVAP control system pressure sensor
- refueling EVAP vapor cut valve
- ORVR system leaks
This is a "jackpot" DTC. It points to so many things you don't know what to check. It is often combined with another DTC which is more specific and therefore more helpful.
http://forums.maxima.org/showthread.php?t=265311
Old Dec 18, 2003 | 04:54 PM
Frank Fontaine's Avatar
Thanks in advance
Most likely, from a practical standpoint, you need a new canister, boost valve, and valve assy. This lamp goes on at around 65k. The parts are around $185 with a 20% discount. Dealer wants roughly 2 hours labor to put it in.
Starrider
Dec 18, 2015 04:43 AM
Steven Orozco
Sep 12, 2015 10:41 PM
dcam0326
Sep 7, 2015 07:26 AM
