5 speed pilot bushing problem
Old Dec 18, 2003 | 07:21 PM
AgaricX's Avatar
Here's the deal. We have done a 5 speed swap and have a problem. We have a Fidanza flywheel and an Exedy stage 2 clutch. BUT there's an issue: the pilot bearing(s) is way to big to fit on the crankshaft, the outside diameter of the bearing is about 2.5mm than the inside diameter of the crank hole opening, weve used 3 different bushing and their all the same.
is there a different bushing that we have to remove, or take a old part out of the crankshaft?
pls help
Old Dec 19, 2003 | 05:41 AM
ejj's Avatar
ejj
pls help
Did you take the spacer at the end of the crankshaft out? Auto tranny's come with a spacer, which might cause the problems you're talking about.
http://forums.maxima.org/showthread.php?t=271521
Max139617
Oct 19, 2016 11:34 AM
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Max139617
Sep 6, 2015 06:02 PM
