How to install sidemarkers like this? *pic*
it's more of a safety thing...too many idiot drivers cutting into a lane I'm cutting into bc they don't pay attention to me. I'm thinking if theres a blinker on the side they'll see me...i'm gonna use this one
so it won't be sticking out as much and itll match my smoked headlights/hyperblack corners...
it's everyone's personal perogative to choose whether or not they want to do this type of mod....whether you think it ruins anything or not...
there are two common ways to install side lights...mine required cutting the fender with a dremel to allow it to pop into place quite easily for replacement of bulbs when needed....the wires are tapped to the sidemarkers in front of the tire...check pics on homepage for more closeups...they are BMW clear sidemarkers i got off EBay.
the other type of lights only require a hole large enough to run the wire thru...much easier but it really depends on the style of mount and how good you are with tools...
Originally Posted by Ludacris
thanks for the help man..what about rust? anything to worry about?
its a side indicators, so i think if you made it a full time signal, you would be SOL for the second function as an idicator. You need a turn signal signal wire (no, not a typo) to indicate when to flash and disrupt. You could splice from the front half of the corner...but you need the wiring diagram for the front corners. it would be really involved, and generally pointless
You can have it wired up, so it will be on w/ your parking lights, and then it will blink alternately w/ your blinkers. To do that, it's just like doing the blinker mod( I forget what its called
Originally Posted by SXN
you mean this one? http://www.vqpower.com/v2/modules.ph...howpage&pid=53
and ludacris....i do understand why you would want to do this for safety purposes...too many people dont pay enough attention
ludacris,
Why don't you just get the turn signal indicator side mirrors, people would still see it from the side.
I really hope you know what doing b/c I ruined one of my cars installing side markers because I didn't know what the h3ll I was doing. It is not as easy as it sounds, at least I didn't think but it is real easy to f*ck up your car. Keep in mind you are cutting into your cars exterior, if you screw it up you will have to buy a new fendor, have it painted and installed. That would be a very expensive mistake, i'm speaking from experience man but do want you want but if it were me I would buy the mirrors.
Originally Posted by climaxing
ludacris,
all the big cities are like that, but so far this mod isnt exactly perfected. Like everyone said, turn signal mirrors are a good option. they would cost a little more, and require paint, but they would also give you the same safety functionality, and you KNOW they will fit.
reflectors, like shiney plastic markers. You know the ones that shine when light hits them. You can get them in a lot of different shapes and sizes too... lemme look for a link later
MaxLife17
Jun 27, 2019 01:37 PM
MikesChevelle
Aug 6, 2015 11:36 AM
