Quick Question about GReddy exhaust
Dec 20, 2003 | 06:29 PM
Ok, I was wondering if the GReddy SP-2 Cat-back would fit on my 97? I'm looking at custommaxima.com and southwestautoworks.com and they both have the GReddy SP-2, but it says they are for 95-96. Which GReddy Cat-back is for the 97-99's if not the SP-2?? Thx in advance.
Dec 20, 2003 | 06:41 PM
the sp1 and sp2 should have a model for the 95-96 and the 97+ they might just not have the 97+ in stock. the sp1 is the same as the sp2, but with less stainless steel/shiney parts. write them an e-mail and see whats up
Dec 20, 2003 | 06:42 PM
Ok, thanks
Dec 20, 2003 | 06:53 PM
no problem, i think if you put the 95-96 exhaust on your car, it would stick out a little bit because of the B pipe section being different, contact them and try and get the right one
Dec 21, 2003 | 07:19 AM
Quote: no problem, i think if you put the 95-96 exhaust on your car, it would stick out a little bit because of the B pipe section being different, contact them and try and get the right one
The rear o2 sensors are different on the 95-96 and 97-98. If you try and use a 97 cat-back on a 96 you will have to have the bung welded shut on the B-pipe. If you try and use a 96 cat-back on a 97 then you will have to have a threaded hole made for the o2 sensor.
Dec 21, 2003 | 03:35 PM
thanks for clearing that up mike, i will know for the future now
Dec 21, 2003 | 03:55 PM
Quote: The rear o2 sensors are different on the 95-96 and 97-98. If you try and use a 97 cat-back on a 96 you will have to have the bung welded shut on the B-pipe. If you try and use a 96 cat-back on a 97 then you will have to have a threaded hole made for the o2 sensor.
Ok thanks for the info.
